1952-59 Ford Driver-side vent cable assembly
Discussion in 'Off Topic Hot Rods & Customs' started by Mr. Tomato Head, Mar 30, 2016.
  1. Mr. Tomato Head
    Mr. Tomato Head
    Does anyone have a simple solution for repairing the driver-side vent cable? It sticks and I am unable to open or close the air vent. My "quick fix" was to keep it in the open position and just disconnect the loop from the vent lever on the fender.
    If this involves totally removing it, is there a trick for doing so? It may just need a good soaking in some cleaning solution. Any special tool required? Thanks...Mato
  2. bobss396
    bobss396
    What year Ford? Mine comes up and is accessible from under the hood. It may be frozen there. With a little work (yeah right..) it comes out. It may need a little lube and persuasion.
  3. 55Brodie
    55Brodie
  4. Texas57
    Texas57
    If it's just the cable that's sticking, Dupont makes a lubricant that's a teflon powder suspended in alcohol. If you can get the cable off, hang it up and drip the stuff thru til it comes out the other end. The alcohol evaporates leaving just the teflon residue inside the cable housing. Lowe's use to carry it but stopped and I've only been able to find it on line. I understand it may be avail at motorcycle shops.
    Edited to change mfg. from 3m to Dupont
  5. Paul2748
    Paul2748
    To remove it, you have to unloosen a nut on the back side of the dash and it will pull out after disconnecting it up front.
  6. buymeamerc
    buymeamerc
    from s.c.,usa
    took mine out, soaked it in evaporust for a week, cleaned and freed it . Then I hung it up and fed "3in1" oil into one end untilkl it came out the other, works great!
  7. cb186
    cb186
  8. bobss396
    bobss396
    Dorman makes a great line of handy stuff. This cable looks pretty stout, so it should work. Choke cables are too flimsy. Still the trick is to get the factory knob to fit on it.
  9. 55Brodie
    55Brodie
    The other trick would be trying to make the loop in the wire that attaches to the flapper. Best bet is to free up the original cable ***embly.
  10. bobss396
    bobss396
    Agreed. But replacements are available used and new. A long cable can be modified into a short cable. Best thing is to remove the cable even if it involves standing on your head to do so. Then you can make a fix-or-replace decision.
  11. Mr. Tomato Head
    Mr. Tomato Head
    Yeah. Great tips. Thanks. Adding it to my "Summer To-Do List". Mato
