1952-59 Ford Driveshaft 302 aod?
Discussion in 'Off Topic Hot Rods & Customs' started by ajracing9, Nov 7, 2023.
  1. ajracing9
    ajracing9
    Hey guys I tried ñooking around but I haven't seen a measurement for drive shafts.
    I found this website
    https://www.southwestspeed.com/?sec...MIroLOis-TgAMVxhKtBh2sSgbKEAQYASABEgJbdfD_BwE
    They'll build a 3" aluminum driveshaft for $350. Which sounds like a good deal to me.
    Where I live there is no drive shaft shop nearby and I don't really want to tow it 30 to 40 miles each way. Plus I'm not sure they can beat 350 in socal. They say to measure from the bell housing to the rear end flange. I measured 61 in on my vehicle I feel that seems so dang long. Anybody by chance have a measurement for that?
    Thanks!
  2. Adriatic Machine
    Adriatic Machine
    Says to measure from the end of the tail housing, not the bell housing
  3. ajracing9
    ajracing9
    Oops, That is correct, I mis spoke. I get 61" from tail housing to diff flange
  4. Adriatic Machine
    Adriatic Machine
    My 59 Ranchero is 60”. However since the rear suspension is lowered 2”, stock length could be a little bit more than 60”
  5. ajracing9
    ajracing9
    Let me feel a little bit better! I think I'm just going to order it and see what happens. Thanks for the replies I'll keep you posted
  6. evintho
    evintho
    Driveshaft out of an '82-'86 Crown Vic is the perfect length. The front yoke slides right into an AOD and a NEAPCO 2-0291 U-joint will connect it to the stock rearend. Driveshafts run $50 at Pick-N-Pull.
  7. ffr1222k
    ffr1222k
    Dennysdriveshaft website has a good form to use in measuring driveshaft lengths. They also ship driveshafts and have fair pricing
    ajracing9 likes this.
  8. the-stig
    the-stig
    Ed Moore Drive Lines 456 S Sierra Way, San Bernardino, CA (909) 888-9859. He made the drive shafts for my Fairlane and my F100. Good Price and product.
    jimmy six and ajracing9 like this.
  9. ajracing9
    ajracing9
    Our local lkq doesn't have many of any pre 90s vehicles. I keep a eye out when I can.
    I'll look into dennys thank you!
    I would love to take to a shop but San Bernardino is about 1.5 hours away. I'll give them a call though
  10. jimmy six
    jimmy six
    The best in the Inland Empire bar none. Perris Auto Speedway go to guy. I took all the measurements he asked.
    It’s best if you have the trans yoke which you can get from any of the suppliers like Summit, Jegs etc . He will tell you how far from bottom to place it, then measure from the center of the front u to the center of the back u then he will make it for you to come and pick up.
  11. Adriatic Machine
    Adriatic Machine
    o_Oo_O
    I’m just curious how did you know what car he has and what application would work o_O
  12. 48ford
    48ford
    What he said
    Take your tape measure with you
    Newer one may fit also
  13. 51504bat
    51504bat
    They did the shaft for my '54 Ranch Wagon with a 302/AOD combo. Measured according to their directions. Fit perfectly. Fair price and reasonable turn around. Highly recommend them.
    jimmy six likes this.
  14. Texas57
    Texas57
    Only to support the "an oem driveshaft can work" discussion, my '57 short wheelbase Custom with a 4.6 dohc and 4R70w ****** out of a '95 Mark VIII uses the unaltered aluminum Mark VIII driveshaft. I did change the 9" pinion yoke to a 1" taller hd version, and a conversion rear u joint. If I remember correctly, I just had to buy a ujoint with different caps to adapt the Mark VIII ujoint to the 9" yoke.
    nosford likes this.
  15. evintho
    evintho
    The car in his avatar is a '54 mainline. The driveshaft info is in post #74 in the FAQ Sticky. I used that info when I went to the junkyard to grab a driveshaft for my '54 with 5.0/AOD and stock rearend. Fit perfectly!
    JeffB2 and Adriatic Machine like this.
  16. Adriatic Machine
    Adriatic Machine
    The magic of the HAMB
    evintho likes this.
