Technical Driveshaft cost?
Discussion in 'The Hokey Ass Message Board' started by carpunk, Aug 14, 2019.
  1. gatz
    gatz
    let me get back to ya on that in a coupla days.
  2. GTS225
    GTS225
  3. jazz1
    jazz1
    Local shop charged $250CDN for mine,,it was about 6' long
  4. 4wd1936
    4wd1936
    from NY
    I just had one done by Performance Driveline in Bakersfield for a 71 Chevelle 400 Turbo/9" Rear. Shaft, yoke and both universals delivered to my door for $320 and it is perfect. Very nice folks also.
    olscrounger likes this.
  5. gatz
    gatz
    The length was shortened a couple inches; is now 49" from U-joint to U-joint.
    I furnished a NAPA 316 U-joint and the company that did the shortening and balancing supplied another similar; as they said there were "rough spots" in it when flexing.
  6. olscrounger
    olscrounger
    Always have new ones made for the 40's we do. New Ujoints, yoke etc--$275
  7. I'm sure there will be some rolling eyeballs on this one, but since I've been doing it for 40 years with no problems, I'll post it. Most of the drivelines I've made were for early Fords with Chevy 4 speeds. I just found a driveshaft with the right u-joints that was too long. Always cut them at the rear end making sure the cut was nice and square. Clean up the rear u-joint retainer (what's this thing called?) and drive it back into the shortened shaft. Make sure it's timed right. I just laid a welding rod across each end and eyeballed them. It will pretty much square itself but some careful measuring will make it perfect. Tack it once, check measurement, tack opposite side, recheck. end up with 4 tack welds. Make a nice mig bead and throw it in the car. Never felt the need to balance one. Have driven thousands of miles with zero problems.
    Nostrebor and Yamagrant like this.
  8. 911 steve
    911 steve
    from nebraska
    I googled "driveshaft repair,reno,nv" & quite a few came up, start there
  9. Corn Fed
    Corn Fed
    I had one made for my '32 Ford about a year ago. All new including yoke and joints for $200 from Fast Shafts in Des Moines IA. IDK if that is their going rate or a special because I know the owners son, but it looked and fit good. They build tons of shafts for the stock car crowd so they know how to make ones that will get beat on and not break.
  10. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    X2 on Tom Woods. Made the splined shaft for my '31 and as I recall paid less than $300.
    gimpyshotrods likes this.
  11. mgtstumpy
    mgtstumpy
    Going rate here is $500 with new weld yokes in addition to a slip yoke.
  12. gimpyshotrods
    gimpyshotrods
    X3. He has made a bunch for me.
