Technical Driveshaft emergency brake
Discussion in 'Traditional Hot Rods' started by tack, Jan 10, 2023.
  1. That actually is a slick idea. I like mechanical E brake hardware but that is certainly something to look into. :cool:
  2. hemihotrod66
    hemihotrod66
    1965 and later Mopars had normal axles.....But 1964 and earlier housings can have normal axles made for them using what they call the "Green Bearing"... I have a narrowed 1964 housing with Moser axles in my hotrod....
    deathrowdave likes this.
  3. Budget36
    Budget36
    I have a 78, 89 and an 03 (all Chevy) with 4 wheel disc. Only the ‘78 has a inner drum for the -whichever- brake. The other two use the calipers.
    Boneyard51 likes this.
  4. gimpyshotrods
    gimpyshotrods
    The lengths that some of you will go to, to avoid a basic axle swap.
  5. gene-koning
    gene-koning
    If you have been around Mopars for a while, 65 was a split year. Most early production 8 3/4 had the tapered axles, and most late production were modern axles. The change over occurred as each plant used the remaining stock of the "old" axle shaft 8 3/4 rear ends, rather then a specific date for the change over. By the 66 model year, all the 8 3/4 rear ends had the modern axle shafts. Back in my junk yard hunting, looking for a 66 model year or newer solved the axle shaft question.
    Two things made those decisions for me, I worked at a gas station that did a lot of brake jobs. After you kill a few tapered axle brake drums or screw up a few axles, you don't give swapping the entire ***embly out a second thought. By the early 70s, good 66 & newer 8 3/4 rears were easy to come by and were chap, no reason to deal with the old tapered axle junk.
    I ran dirt track cars, "green bearings" were not something I would install to replace a tapered roller bearing in a rear end that might end up on the dirt track. Aftermarket axle shafts were out of my budget when the OEM modern Mopar stuff still worked for what I needed. Aftermarket axle money bought things I needed worse. I could buy 8 3/4 rears back then for $50 or less, or buy the entire car the 8 3/4 was under, for $75 and have parts I needed and made money off the stuff I didn't need.
    Anything with tapered axles got the entire rear end swapped out in a heart beat, with no afterthoughts. The old rear end hit the s**** pile unless it was a Sure Grip, or had a decent hot rod gear ratio.
    I've not dealt with "modern GM" anything recently. How did GM lock the calipers for the E brake?
  6. Budget36
    Budget36
    I’ll get a pic or two for you tomorrow when it’s light out and send you a PM.
  7. gene-koning
    gene-koning
  8. gimpyshotrods
    gimpyshotrods
    There is a mechanism inside of the single piston bore, that is turned out by a lever that sticks out of the backside of the caliper.
    These were made in much the same design for both the pre-Metric, and Metric-era caliper versions.
    Very similar, but different in scale. The pre-Metric ones are larger, and are for thicker rotors.
    Budget36 likes this.
  9. Driveline park (or emergency if you like) brakes were not a good idea. Mother Mopar supplied a wood chock with those cars so when you had to change a flat in the rear it wouldn't roll off the jack. Most if not all of those OEM chocks have disappeared by now ('What the hell is this for?') and you won't know you need it until you do...
  10. Budget36
    Budget36
    I don’t recall the spring, now I may have to pull the wheel off!
  11. gimpyshotrods
    gimpyshotrods
    Those often disappear at caliper change time.
    Rebuilds are not sold with the nut, arm, or spring, on the earlier calipers.
  12. 34 5W Paul
    34 5W Paul
    from Fresno CA
  13. The 4x4 places sell a heavy duty version of the caddy e-brake/parking brake/whatever caliper.
  14. gimpyshotrods
    gimpyshotrods
    I had them on my 4x4 rig, with TSL's and 1-ton axles, for a decade, until I sold it.
    They worked well.
    anthony myrick likes this.
  15. 38Chevy454
    38Chevy454
    And to stray sort of off subject, while you are byp***ing those brakes, you should be pulling the (likely) 3.55 geared center section. That's the popular source for them. Although getting kind of scarce in junkyard nowadays.
  16. Karlb
    Karlb
    I know this threads got few years on it but, what calipers did you go with and is everything still working well? Thanks
  17. Mimilan
    Mimilan
    Use a cable pull caliper for trailer brakes
    They are asymmetric forward pull and fit L or R so when mounted sideways you can have the cable on either side.
    Mechanical trailer brakes last for years [ a lot longer than the life of this thread ]
    Karlb and RICH B like this.
  18. deathrowdave
    deathrowdave
    from NKy
    I owned a 2.5 ton military truck with band and drum on rear on the trans it would hold the truck fully loaded from moving but NOT stop a moving loaded truck . It would smoke and over heat the band as soon as applied . Ask me how I know this fact ?
    Karlb likes this.
  19. Karlb
    Karlb
    Thank you
  20. dan c
    dan c
    i thought all the old mopars used a driveshaft-mounted e-brake. i remember reading dad's "consumer reports" magazines as a kid, and they thought that setup was dangerous...
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    They did, were large-ish drum brakes, heavy as hell. & the extra beef at/on the end of the trans-case, just for the drum-system - bleach.... ;( . They worked very well as a *parking* brake, less so as an emergency brake, although better than nothing. A disc brake setup to replace the drum, could probably cut off 50lbs... :D . Still, better on the diff, pinion ok, axles best. Still better than the oem ford T stuff...
    Ahh, the fun of hotrodding & modifying... ;) .
    Marcus...
    dan c and Karlb like this.
  22. GuyW
    GuyW
    Add additional unsprung weight for a driveshaft disc on the rear end, when there are existing drums on it?
    Nah - that violates a basic rule of hot rodding (ie, "add no fat onto the ***")
  23. nrgwizard
    nrgwizard
    from Minn. uSA
    Not if he converts to discs, & also not if the oem drums have *no* emergency cables/linkage...
    Marcus...
