Technical DRIVESHAFT MEASURMENT
Discussion in 'The Hokey Ass Message Board' started by Old GW, Dec 17, 2017.
  1. Old GW
    Old GW
    AGAIN!!!!!. Can some one tell me the proper way to measure for a new drive shaft?
    Thanks for any help.
  2. pitman
    pitman
    Not knowing your rear suspension in detail...
    Place the front yoke into the trans, have 2 or 3" wood block under the rear tires, AND wheels(4) chocked! W/trans in neutral, rotate the front yoke till it is at 9am - 3pm, pull it rearward approx. 3/16". Tape measure the distance to the rear yoke center (already set at 9am-3pm) there is your new shaft length. Does depend on how much fore & aft movement the suspension req's. A more accurate measure slides the 'used' front yoke in, only as far as the clean seal worn 'ring' on the outside of the yoke. /If you use the method in the following post you'll be able to remove the shaft easily, when u-joints need attn./
