Driveshaft Question
Discussion in 'The Hokey Ass Message Board' started by geoz3, Jul 23, 2013.
  1. geoz3
    geoz3
    I just picked up a 37 project truck with a 350 and 700r4 trans, the driveshaft fits,from the reaend up to the rear of the ******, but about 6 inches of the shaft is exposed, is this a problem ?
  2. themoose
    themoose
    I have always done it this way......with the driveshaft at ride-height you should have 3/4 to 1 in. yoke showing.
  3. Gene Boul
    Gene Boul
    6" exposed yoke would put the universal joint way too far back for any kind of stability. Unhook the driveshaft from the rear-end and see how far you can push it into the ******. If it will go say 5" then subtract an inch and get a driveshaft that much longer.
  4. geoz3
    geoz3
    OK thanks guys
