Hot Rods Driveshaft too short?
Discussion in 'The Hokey Ass Message Board' started by Kid Jeff, Feb 1, 2018.
  1. Happydaze
    Happydaze
    I'm feeling a bit scrambled right now.
    1" stick out is usual, but the amount 'in' is another matter. That'll depend on the length of the yoke and depth of the trans. You don't want to it bottom out if you insert that extra inch. So long enough, but not too long, but not too short. What were we talking about??
    Chris
  2. gimpyshotrods
    gimpyshotrods
    Grade-8, and a little hardwood will fix it:
    Bandit Billy and Kerrynzl like this.
  3. oldtom69
    oldtom69
    from grandin nd
    quick note-if you are using the common 9 inch ford rear the different size pinion yokes can vary the driveshaft measurement by an inch or so
    gimpyshotrods likes this.
  4. gimpyshotrods
    gimpyshotrods
    Put your existing yoke in the transmission. Push it in until it bottoms out.
    Pull it back out 3/4" if it is a short travel suspension setup. Pull it out 1" if it is a long-travel suspension setup.
    Then, measure from the center of the eyelet on the yoke, to the center of the eyelet on the pinion yoke. That is your operational length.
  5. gimpyshotrods
    gimpyshotrods
    YES! There are deep and shallow pinion yokes. This is the case with other rear axles, too!
    You can vary installed length there, too.
  6. gimpyshotrods
    gimpyshotrods
    The correct IN measurement it everything but the 3/4" or 1" that I mentioned above.
  7. bobss396
    bobss396
    Good advice, I can live with all of the above. I used a stock Power Glide yoke when I measured for my driveshaft and there was not a lot in the transmission. The splined area was not that long. So find one of those and see what it measures up as.
  8. DDDenny
    Bob
    (If) you mean correlate the length of a PG yoke to that of a T400 yoke, apples and oranges, but maybe I didn't understand your post.
    I'm sure you know it, but if not, see my post #11.
  9. wutnxt
    wutnxt
    Speedway sells a (affordable) longer yoke. If it’s too long you can cut it down. I’ve got one in my ‘40
  10. DDDenny
    Hey neighbor!
  11. wutnxt
    wutnxt
    I’m still kickin’
