Technical Driveshaft work in Austin
Discussion in 'The Hokey Ass Message Board' started by Austin Bubbletop, Jan 28, 2018.
  1. Austin Bubbletop
    Austin Bubbletop
    from Austin, TX
    Installed a Ford 9" in my 61 and now needing a longer rear DS section. Looks like my choices are Scotty's and Inland. Who do you guys like?
  2. Dreddybear
    Dreddybear
    I used Scotty’s. Happy with em.
  3. Anderson
    Anderson
    I’ve only used Inland but only because I always forget about Scotty’s. Inland is expensive but the work is good. I plan to try Scotty’s next time.
  4. Redrodguy
    Redrodguy
    Driveshaft Spe******t Inc. - San Antonio, Tx. did an excellent job for me.
  5. 55styleliner
    55styleliner
    I need 3 driveshafts done. Subscribed.
  6. 325w
    325w
    Local company in Hurst Tx. is very good. They give you a form to fill out. If your measurements are correct the shaft fits. Used them about 15 times
  7. Austin Bubbletop
    Austin Bubbletop
    from Austin, TX
    Went by Inland yesterday. $300 to retube the rear section. Plus extra to dis***emble the driveshaft. I’m on hold until I figure out if that’s the route I want to go. Scotty’s is a drive for me or I would have went there as well.
  8. Austin Bubbletop
    Austin Bubbletop
    from Austin, TX
    Ended up using Scotty's. $175 out the door.
    Anderson likes this.
