Driving at night.
Discussion in 'The Hokey Ass Message Board' started by Doc Squat, Aug 4, 2012.
  1. Doc, you and I have the same problems. I had halogens in my 32 headlights. Wasn't worth squat. I bought these because of the combined turnsignals. I can now see way down the road.
    http://www.rodworx.com/product.php?item=569
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    Bob, does your wife know you're prowling around at night?
    kidcampbell71 likes this.
  3. lostforawhile
    lostforawhile
    I just set up my driving lamps to switch on with the high beams and the yellow fog lamps with the low beams, you shouldn't be running the high beams in rain or fog anyway, I can't see **** but reflected light with that, good ambers in bad weather on low beams show the edges of the road much better
  4. Doc Squat
    Doc Squat
    from tulsa, ok
    Yep. I was doing a wedding.
  5. The problem with the kit's for old lights are that the lenes are not set-up like sealed beams (beam pattern on the gl***). With the stock lens you get a really bright flood light vs. the focused beam of the sealed, you need to run with the high beams on and the lights pointed down with the halogen kits. I've been thinking of the sealed beam conversion for the '28 but the new kits put the sealed beam behind the stock lens and you might run into some problems at night that way. The old sealed beam kits mounted them so they took the place of the lens but looked really goofy. I found this out on my '60 elco, I bought some kits in the late 90's from the swapmeet to convert the sealed beams to halogen inserts, they ****ED. Made a really big flood pattern directly in front of the car and when you adjusted them out further the light was weaker (hence the having to use the high beams). I noticed the new housings had a lot less lines and a different pattern then the sealed beams......so the pattern on the lenses makes a BIG difference.
    Functional but ugly:
    Really worthless:
    32 lens:
    Sealed beam light:
  6. KENDEUCE
    KENDEUCE
    I looked at new reflectors and lense which is a new product from Julliano. Anybody try them?? Not the same as HRP was showing.
  7. Doc Squat
    Doc Squat
    from tulsa, ok
    Thanks for all the suggestions and help guys. I have done most of what a lot of you said to do ie Clean windshield, eye check (I do this once a year) . I think I'll try Hot rod primers advice and get some new reflectors for a start. Many of you asked what kind of car and I'm driving a 1932 Ford tudor. I really didn't see a add-on light that I thought would look on a 32. I know some of the euro style would do the job but would look like ****. Any and all additional info will be welcome. I've got to do something before I reall fu*k up. Thanks guys!!
  8. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Jagman;
    AFAIK; Zenons require a lot of power, an automatic "dimmer", & the *two* level-sensors ( one front & one rear), + the computer to keep them properly aimed - after they are set by a competent mech, & recognized as such by the computer..
    The "dimmer" isn't, as such. What it is, is a set of vanes (flaps), in the bulb, that move to cut off (deflect downwards) some light from the bulb. Don't think they are ever "wide-open", as that'd blind every oncoming car. & you don't need to see above the tree tops, anyways.
    I'd like to find some "universal" type retrofits, & esp not have them cost upwards of 500->800+ USD.
    But I *do* like the light from them... :D .
    Marcus...
  9. Shaggy
    Shaggy
    from Sultan, WA
    I'd just load up a seeing-eye dog in the p***enger seat.....
  10. RagtopBuick66
    RagtopBuick66
    I heard they're developing braille road signs so the legally blind can drive, too...
  11. RagtopBuick66
    RagtopBuick66
  12. HOTRODPRIMER
    HOTRODPRIMER
    Doc,Drake has the kit to convert your headlights in his summer sale catalog until 8/17/12.
    Sale price is $108.00, and you won't regret it!
    # B-13027-QK-12 and you need to tell them the catalog code FL512A
    When you get them installed drag this thread back up and post your thoughts. HRP
  13. HOTRODPRIMER
    HOTRODPRIMER
    Ken,Their kit is designed for 37-39 Fords only. HRP
  14. jonnyonedrip
    jonnyonedrip
    from canada
    Maybe the deal here is to set up your lights with the real ugly ones that work best and the original lenses over top. But make it in such a way you can remove the lenses easily if you need to drive at night. No one can see your actual lights when they are on at night, then you get the best of both worlds.
  15. KENDEUCE
    KENDEUCE
    HRP: I just saw them at Louisville in there booth on Saturday. They looked different than Drake and I want turn signal in light too.
    I hope Doc does feedback!
  16. HOTRODPRIMER
    HOTRODPRIMER
    Ken,I have always liked the big original head lights and have tried all the magic cures for the lighting problems that are inherent with the originals,,from the re pop silver replacememt reflectors and bright bulbs to the rings that adapt the sealed beams (FUGLY with a capital F) to the original headlight buckets and about 5 years ago I tried the new chrome plated plastic kit offered by Drake.
    I couldn't believe the difference in the light that these things throw out,,the reflectors shape is entirely different from what we normally see and what I have be told is similar design to that of a Mini Cooper
    Before I sold my '32 4 door I installed them and bought a set for my 1932 coupe project. HRP
  17. The whole wedding hell my ol lady gets real ticked when I just do a couple of strippers. :D
  18. Doc Squat
    Doc Squat
    from tulsa, ok
    Ok I took hotrodprimers advice and ordered the kit from Bob Drake. Will be filing a follow up report soon.
  19. Jimmy2car
    Jimmy2car
    from No. Cal
    Doc, I'm doing the same for my 32. I'll post results also.
    HRP, thanks for the call. I appreciate it
    Jim
  20. lostforawhile
    lostforawhile
    don't laugh, Washington has actually spent money on researching braille highway signs, since it's a recognized disability, Big brother says they have to be accommodated to, even though they can't drive. Not making fun of the blind, just the people in Washington who are blind by having their heads up their ***es. How do you read an overhead braille highway sign? stop traffic,get on a ladder and read it?
  21. RagtopBuick66
    RagtopBuick66
    Those 65 MPH speed-limit signs would be a ***** on the old fingertips as you whiz down the freeway... :eek:
  22. refried confusion
    refried confusion
    __________
  23. RagtopBuick66
    RagtopBuick66
    ouch!
  24. BOOOOOO!!! Drake doesn't have A stuff.
  25. 48 Indian Rag
    48 Indian Rag
    from conn
    Check out page 41 of Julianos new catalog for 32-34 headlights
  26. jimbousman
    jimbousman
    I chuckled when I first looked at the rear pull down shade over the rear window on my "A" coupe, I thought "This would be cool for the drive-inn." That was until I was told it was for night driving to prevent the headlights from reflecting off the rear window. From then on I never drove at night without it.
  27. lostforawhile
    lostforawhile
    I knew right what you were going to say lol, I remember the first time my dad drove his 28 Chrysler he didn't know what the shade was for either,until , he saw the "lights" coming right at him and nearly drove off the road. It's kind of like those infinity mirrors.
  28. I wonder about the signs next to the bathrooms in buildings. How does a blind person know that they are there?
    Seriously, after five surgeries in both eyes to correct cataracts and a torn retina, I really appreciate the issues we are all facing driving at night.
    I just scored a 47 Tudor, and I'm going to be looking at improving the light signature at night.
    I live in a heavily wooded area North of Dallas, and light is at a premium. So keep up the comments and recommendations fellas.
  29. pitman
    pitman
    They did sell me a set for A buckets, however I still have the "low in front" bright spot w/far less projecting out forward.
    HRP, or other mavens of illumination, would you have any alignment suggestions I might try here? Thanks, Pitman
