Hot Rods Driving position in A Roadster
Discussion in 'The Hokey Ass Message Board' started by woodhawg, Apr 28, 2016.
  1. woodhawg
    woodhawg
    Finally getting to drive the A in my avatar and after a while my right leg gets cramped up. I have to have my foot angled about 45 degrees from straight up to fit my big **** and big foot in the thing. Was thinking about making a wooden block, covering it with the same carpet and attaching to floor so my foot could have something to rest on and not have my toes just dangling in air.
    Anybody done this or have comments.
  2. oj
    oj
    Aren't they stock in a Model 'A'?
  3. woodhawg
    woodhawg
    Nothing on this is stock. Had no floor in it when I got it.
  4. F&J
    F&J
    Can you put up some pics? Maybe from both sides of the p***enger compartment.
    Someone will come up with some ideas that way.
    I just finished the 3rd reworking of all 3 pedals in my 32 so my long legged son could drive it too. So, I know what you are going through.
  5. roundvalley
    roundvalley
    Buy a Model A foot rest that is adjustable and has a rubber cap. Easy install.
  6. DDDenny
  7. woodhawg
    woodhawg
    Will post some pics tomorrow morning. Looked on line and saw the MAC's thing installed to the right of the standard accelerator pedal. That might work, but will post as promised and see if anyone still thinks that is the way to go.
    Thanks guys
  8. Jalopy Joker
    Jalopy Joker
    for my Model A had the front edge of the seat base built up about 3-4", when upholstered, to give some support to back of thigh which raises leg to give a little more comfort & leg room.
  9. 26 T Ford RPU
    26 T Ford RPU
    I had the same problem in my T RPU, my solution was to make the seat back thinner thus allowing me to sit further back and straighten my legs and get them under the steering wheel, my feet are now straight. JW
  10. dirty old man
    dirty old man
    Woody, being 6'3", with a size 14 shoe, a weight of 245#, and 78 years old, I know where you're coming from on gas pedal comfort on long drives. IIRC, yours is a Brookville body as is BGII, my "A" roadster. I got my "s****" pedal aftermarket, as none supplied with car when I bought the mockup a friend started.
    Being 78 and playing with old Fords for many years long ago, I remembered the foot pesdal depicted above as OEM in several old Fords I owned/drove 50-60 years ago.
    But until you posted this thread I didn,t know you could get repro foot rests from Mac's. Thx yall, for cluing us in.
    With a "s****" pedal and this rest, a properly adjusted pedal and rest height/location, you just roll your foot to the left to increase throttle pressure or opposite to reduce. For full throttle you twist your ankle to the left a bit so foot is off the rest, then "mat" the s****.
    Think I'll install one of these after I get home from Steel in Motion next month. Should make part throttle cruising much easier. Trailering up there and except for return road I wouldn't have much need of a throttle foot rest other than the "mat" for full throttle, LOL!
  11. woodhawg
    woodhawg
    HI Dave,
    Thanks for comments. Mine is original Ford body but Brockville is the same I think? Will post pics in a little while. Just got back from veggie lunch and is almost nap time.
  12. Blues4U
    Blues4U
    from So Cal
    Well I'll be..... I had no idea. I've just been resting my foot on the heel of my foot, and yeah, it can get tiring like that, sometimes rather quickly too. My knee ends up way over to the right, leaning against the shifter, or against my wife if she's riding with me. This is great info, thanks. I'll have to give this a try (me thinks Mac's is gonna get a bunch of orders for these foot rests all of a sudden and wonder what the hell happened. :D )
  13. DDDenny
    Maybe I"ll get a discount for the referrals huh', right.
    I have been considering them for my roadster too but it is so far off from that stage that I may just think on it for now. Even having more room than an A, still looks like a good idea.
    Blues4U likes this.
  14. woodhawg
    woodhawg
    Here are the photos of what I am talking about. Sorry for ****py iPhone photos. Not sure I understand the Model A thing would help? When I drive my Chevy truck my right foot is in about the same position but it leans on the transmission tunnel and I have no strain on my leg. IMG_1397.jpeg IMG_1398.jpeg
  15. I don't see how raising your foot will help. The s**** appears to be under the arch or center of your foot unless I'm reading the picture wrong. You want it under the ball of your foot/toes. I think you need to raise the foot feed ***embly up higher.
  16. mike bowling
    mike bowling
    X-2 ^^^^^^Lots of adjustments you can make, and from the picture maybe if you moved the whole ***y. up a little you could straighten out your foot??
  17. Blue One
    Blue One
    from Alberta
    Looking at your pictures, your throttle pedal is way too low. The s**** pad of the pedal should be on upper pad of your foot just under your toes.
    Nothing you do will help until you correct that.
    dana barlow and 1927graham like this.
  18. DDDenny
    If your trans/belhousing isn't too close to the floor and you don't mind moddng the floorboard, you can sink a heel cup into the floor, seen it done many times, gains some extra space, I have considered it for my car.
    motoandy likes this.
  19. el Scotto
    el Scotto
    from Tracy, CA
    Yeah I agree with the other dudes with moving the pedal.
    I'm a 6'3" 275 lb gorilla with long legs and had no cramping issues driving a '31 roadster for hours...
  20. woodhawg
    woodhawg
    OK will look tomorrow sometime after I finish burning at the farm and see about moving it up. Would it accomplish the same thing if I shorted the lever the s**** is attached to or would that mess up the geometry and make it hard to push or something crazy?
  21. No and yes, in that order.
    sjm1340 likes this.
  22. My thoughts exactly.
  23. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    This is what I saw also. My s**** is right about the ball of my foot. My left leg is straight out, almost, with just a hint of bend. It rests next to the steering column. Right foot is at an angle but not much DSCN0830.JPG DSCN0829.JPG
    AHotRod likes this.
  24. dirty old man
    dirty old man
    Woody, now that you have postred some pics, I agree, your pedal is too low and should fall under theball of your foot with your heel on the floor. And no, don't shorten the arm, move the whole ***y. UP.
    sjm1340 likes this.
  25. 26 T Ford RPU
    26 T Ford RPU
    An important factor when setting my s**** gas pedal was the natural movement from the gas to the brake peddle. JW
  26. woodhawg
    woodhawg
    Thanks Dave, Too tired today to mess with it, but soon for sure. Has to be addressed before SIM!
  27. model.A.keith
    model.A.keith
    I had some issues with leg room, ended up changing the shift leaver from a 23'' to 12'' problem solved...
  28. woodhawg
    woodhawg
    Finally got around to doing something. Did find out that the shoe I wear makes a big difference in the amount of room my feet have. Size 12 1/2 tennis shoes are a lot bigger than my boat docker shoes. But I did make a device shown in the photos. 16 gauge steel cut and formed to match floor shape and attached to front 2 screws of the shifter boot ring. 2x4 wooded block for my foot to lean on. MUCH better! IMG_1435.JPG IMG_1438.JPG
  29. Blue One
    Blue One
    from Alberta
    Unless you moved the pedal up so that the s**** sits under the ball of your foot you still have a far more serious issue than just comfort.
    dana barlow likes this.
