Hot Rods drop arms
Discussion in 'The Hokey Ass Message Board' started by donga, Feb 23, 2020.
  1. donga
    donga
    got some so cal drop steering arms drag link ball end seems to long .have to pack with washer to make it tighten enough.just wondering is there a different size ball type joint to fix problem
  2. Mr48chev
    You are using Ford tie rod ends with them? Or the same 7 degree taper as Ford.
    It could just be that your tie rod ends were designed for thicker steering arms if the taper is right.
