Drop-axle in AD chevy truck problem
Discussion in 'The Hokey Ass Message Board' started by gasman, Oct 11, 2006.
  1. gasman
    gasman
    from Nebraska
    The following are true:
    1: I am putting a 3" dropped axle into a 50 chevy half ton.
    2: I spaced the steering box away from the frame 2" due to a sbc transplant to get room for exhaust manifolds.
    3:When axle was dropped the distance between kingpins was reduced, not sure by how much.
    4: Frame now prohibits installation of steering arm and draglink.
    5:Tie rod will be flipped to clear springs.(this is not a problem)
    What do I do:
    1: Bend draglink like so ~ in order to compensate?
    2: Bend radius of steering arm to a tighter radius?
    3: combination of 1 and 2?
    4: your suggestion?
    5: notch frame (don't like this one much seems draglink likely to bind)
    Help me please
  2. squirrel
    bend the steering arms and the pitman arm.
  3. gasman
    gasman
    from Nebraska
    would bending the pitman be better than bending the draglink. The pitman appears to be cast
  4. squirrel
    should be steel
  5. gasman
    gasman
    from Nebraska
    is it ok to bend in place or should it be removed from the steering box?
  6. squirrel
    take it off, you've gotta get it pretty darn warm to bend it, and it will cook the seal in the steering box
  7. gasman
    gasman
    from Nebraska
    Thanks will do.
  8. squirrel
    might do some research on bending steering parts properly, safety is involved!
