Hot Rods Drop axle steering arms
Discussion in 'The Hokey Ass Message Board' started by 29tudorA, Apr 17, 2023.
  1. 29tudorA
    29tudorA
    Hey everyone I’m still learning all this stuff so take it easy on me… I have a speedway 4 inch drop axle on my model a tudor and speedway round back spindles… can any one point me in the direction of steering arms I’ll need ? Please and thanks in advance
  2. krylon32
    krylon32
    from Nebraska
    Depends on whether your using bones and what year they are or hairpins.
    WTF really and mad mikey like this.
  3. 29tudorA
    29tudorA
    Aftermarket bones from Boling brothers
  4. Kevin Ardinger
    Kevin Ardinger
    I used the Heidt bolt thru dropped arm on my Tudor. I personally like that bolt through design as opposed to the threaded one. Just my opinion. I think they’re actually sold through ch***is engineering now. You need to make sure the linkage will p*** under the wishbone. I had an issue with it.
    okiedokie likes this.
  5. krylon32
    krylon32
    from Nebraska
    There are dropped thru bolt steering arm available from Roadster Supply that will put the tie rod under the bones. The Boling Brothers bones are replicas of the 37-40 bones. Problem with Roadster Supply all the thru bolt arms are stainless and expensive. You might also try Pete&Jake's they did make a run of the Ch***is Engineering/Heidt's deep drop thru bolt arms and they may have some left.
  6. SundanceKid
    SundanceKid
    from Utah
    Pete & Jake's are out of the dropped arms and don't have plans in the near future for a production runs due to the additional cost of the CE rights.
  7. krylon32
    krylon32
    from Nebraska
    Call Ray at Roadster Supply 714-583-4118 tell him your application and ask if he would advise AHR-60306 deep drop plain steel thru bolt steering arms. If you order make sure you also order the bolts.
    deuceman32 likes this.
  8. Scott079
    Scott079
    from Canada
  9. krylon32
    krylon32
    from Nebraska
    079. The Speedway arms you refer to are not thru bolt but they are cheap. Wonder why?
  10. alchemy
    alchemy
    Huh? Isn’t cheap always good? o_O
  11. I have those from Speedway, 20+ years and countless miles, no problems… guess Im just one of the lucky ones
