Does anyone know what this tank is off of? approximate dimensions length 11' 6 1/2" width and height (in center of tank) 21" cir***ference 67 1/2" Wing on the rear of tank length 37 1/2" width at tips of vertical uprights 26" 120 gallon weighs 87 lbs empty Part # 172-48250 Model # F-86 Material AL Alloy # 22 Does have a hole from sitting on the ground Mounting pins and sway control is still in tack Does have a few dents that could be fixed very ez
I would venture to say , "F-86", since that's what it says on the data plate.... Want me to come and get it? We, ( My car club), built a downhill racer out of one like that, x-cept made from steel.............Looked identical, to include the hole rotted in it..All the other fittings on our tank were identical to those, however, ours had no data plate. I'll come and get it , if you like.
