Dropped axle issue !!!please help!!!
Discussion in 'The Hokey Ass Message Board' started by Fireant, Jun 20, 2011.
  1. Fireant
    Fireant
    from Texas
    I need some help please. I'm getting ready to put in a dropped axle under my truck. The problem is that the dropped steering arms are hitting the axle. How do I fix this problem? Does anyone make steering arms that fit closer to the spindle? Do I look for a new axle?
    Any help would be greatly appreciated.
    Ant
  2. brandon
    brandon
    Think ch***is engineering has a steering like your looking for....
  3. tommy
    tommy
    I bet you will get a lot more accurate help if you included the make and year of the said truck
  4. Fireant
    Fireant
    from Texas
    It is a 40 ford truck and it has a original axle that was dropped and stretched.
    In the attached picture you can see how the steering arms don't meet flush to the spindle and is hitting the axle.
  5. chronisterracing
    chronisterracing
    from N.Il.
    I could be wrong but it looks like the spindle is up side down. looks like there is a ton of positive camber in it or maybe its just the way the pic was taken.
  6. Fireant
    Fireant
    from Texas
    This is a stupid question, but is there a driver side and p***enger side to an axle? If so how can you tell the difference?
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    X2, that would appear to be the problem. Everything I've ever seen it's on top. Sorry Lone Star that I don't have a better answer.
  8. Sheep Dip
    Sheep Dip
    from Central Ca
    X3 ..but I'm not there either
  9. brandon
    brandon
    Had this issue with a car of mine....I polished the arms and the axle....till they cleared _
  10. 32 hudson
    32 hudson
    I think the spindle is on upside down also.
  11. metalman
    metalman
    On my 40 with a dropped stock axle I had to do a little clearance grinding, just took a tad off of both. There is a front and back, makes a differance on the tapered kingpin lock pin/ steering stop.
  12. Mr48chev
    According to the instructions that Speedway shows for installing the king pins you have it right http://static.speedwaymotors.com/pdf/910-32121.pdf
    I'm with Brandon in that I think that you are going to have to polish in a bit of clearance to get it to fit. It looks like the problem is in the way the axle was dropped. Not bad but it doesn't have that curve out at the spindle boss that a lot of them have and angles off pretty steep.
  13. Martin_F
    Martin_F
    Hard to tell from this picture.
    Maybe you can post one that shows the whole axle with both spindles on there.
  14. thorpe31
    thorpe31
    from nor-cal
    x2 for Ch***is Engineering
  15. My steering arms had to be ground just a little to clear. The pic does look odd with respect to camber. Is it just the picture?
  16. Fireant
    Fireant
    from Texas
    Does the tapered lock pin nut face the front of the car or the rear?
  17. cruzace
    cruzace
    from tustin
    Nut faces the rear
  18. 296 V8
    296 V8
    from Nor~Cal
    You just need to grind the arm and or the axle a little.
    Stock ... the lock pins go in from the front . If they don’t want to go simply run a 9/16 drill threw the hole.
  19. Fireant
    Fireant
    from Texas
    Everyone, thanks for all the help.
    Ant
  20. 296 V8
    296 V8
    from Nor~Cal
    The problem is
    With those later (37 to 48) axles …. Its hard to get much drop in the first place and even harder to make sufficient room in there for the steering arms.
    Ad to that them kinda steering arms are made to fit new axles that have a mile of space there …….... you get the idea.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    so, you flipped them left for right, and, or.. put them on right side up?
    eh?
  22. metal man
    metal man
    Your problem definately comes from the odd way the axle is shaped. The '40 axle doesn't drop as well as the earlier ( model A or 32-36) axles.Those bolt on steering arms are also more intrusive than the original Ford arms. If you put real Ford spindles on it with the steering arms attached,I think it would clear. That is if a little grinding doesn't do the trick.EDIT..296v8 beat me to it.
  23. kkustomz
    kkustomz
    from Texas
    If the spindles are on correct, you need to make a new set of steering arms that has a drop as well. Not sure how close to me in texas you are?
  24. 55 Mercury
    55 Mercury
    Ch***is Engineer make a bolt on steering arm that drops out the bottom and they work well on the 40 axles. I also like to use the stock spindles and steering arms. You can bend them tighter and get the clearance. The super bell style of steering arms don't work well on the 37-47 axles.
    www.droppedaxles.com
  25. Goztrider
    Goztrider
    from Tulsa, OK
    BEFORE you grind anything....
    You need to lay this axle down on a flat surface with the spindle straight out, step back, and then take a picture of the spindle shaft. I don't know if it is this picture or not, but from the way it looks your spindle is on upside down.
    It should point straight out and be 'level' with the axle and not bent downward facing. If it is facing downward, when you put the hubs, wheels and tires on, they will be laying out extremely far at the top.
    Trust the advice given above about the spindles. The picture may be deceiving, but I'd hate to clearance the steering arms and them not need it because of my own mistake.
