dropped axle
Discussion in 'The Hokey Ass Message Board' started by lubber, Nov 22, 2008.
  1. lubber
    lubber
    from so. calif.
    Looking for some help! Want to install a 3" - over stock dropped axel on my 34 Ford pick up. Would like to bend the steering arms up - and run tie rod over radius rod. Has any body tried this? Looking forward to your info. or opinions. Thanks, Scotty:confused:
  2. lowsquire
    lowsquire
    from Austin, TX
    Ive got a 32 truck, and Im running the steering arms over the wishbone, with a Chassis engineering forged dropped axle and 39 stub axles, they only needed to bend up maybe an inch, then you re-taper the tierod holes from the other side so the tierod goes in from the top. this Trick is only a good idea if you have a fairly high arch spring, and then use a bump stop so the tierod tube cant get crushed between the fame and the wishbone .
  3. Corn Fed
    Corn Fed
    I did exactly what lowsquire described on my Model A PU that is using a '34 front axle and (split) bones. I had to trim the back edge of my crossmember so the tie rod wouldn't hit it. You will probably have to do the same on your '34 crossmember.
  4. 296 V8
    296 V8
    from Nor~Cal
    I put together a front end for a friend of mine (34 rpu) with a stock wish bone and a 3’’ dropped axle. He wanted the tie rod under. I had to get the longest steering arms they sell and still had to bend them down about a half inch.
    If your planning on running split bones, keep in mind different years of bones have different (up &down) offsets in relation to the axle that can give you more tie rod clearance.
