Technical Dropped front I-beam vs reversed eye springs
Discussion in 'Traditional Hot Rods' started by cammer8, May 22, 2017.
  1. cammer8
    cammer8
    I have a 1934 Ford pick up .I'd like to know the pros and cons between using a drop front axle or reversed eye springs to lower the car. I need new springs anyway.
  2. alchemy
    alchemy
    How low ya wanna go? A spring will only get you so far.
    LOU WELLS likes this.
  3. cammer8
    cammer8
    2 inches would work. Would the ride suffer?
  4. A reversed eye spring will give you about one inch drop and switching to a Model A front cross member will give you another inch.
    I used a reversed eye spring,Model A cross member and a 4" dropped axle in my old pickup but I wanted it low. HRP
    j-jock, HotRodRyan, LOU WELLS and 3 others like this.
  5. Blade58
    Blade58
    from apopka ,Fl
    I removed 2 or 3 leafs every other one ,that is what I did for my 38 truck and it actually had a softer ride if you have bump stops they may need trimming
  6. alchemy
    alchemy
    If you get a spring with reversed eyes and a flatter arch you can surely get those two inches.
  7. MIKE STEWART
    MIKE STEWART
    Put in a Posie Super Slide in both of my 1939 Ford Coupes - The last install was about 2 months ago in my Dad's Coupe. I got about 2 inches of drop - the original spring was double packed with long pairs - for a 371 J-2 Olds in the 1950's. - looks much nicer - has original axle and unsplit wishbones.
  8. Jeff34
    Jeff34
    On my '34 pickup, I reverse eyed the spring and removed 3 leaves. I had 4 out, but the spring center bolt was bottoming out against the axle, so I put one back in. The truck rides softer than stock, and I like the ride height. I'm running 6.00X16's on the front. [​IMG][​IMG]
    Jet96, thommoina33 and mgtstumpy like this.
  9. cammer8
    cammer8
    Thanks guys, I appreciate the info!
  10. Atwater Mike
    Atwater Mike
    Flat spring without a Dago axle is likened to nylons and tennis shoes. 'Almost...'
  11. Cliff Ramsdell
    Cliff Ramsdell
    Another question would be your brake setup. If you still running the stock mechanical brakes a dropped axle will affect this as the angle for the brake actuator will move.
    A reverse eye and lower spring is a good choice here.
    Cliff Ramsdell
  12. Jeff34
    Jeff34
    Good point. I should have mentioned that I run mechanical brakes and want to stay that way, which limits my lowering ability.
    PhredH likes this.
  13. 1934coupe
    1934coupe
    All good questions and answers, I find this post to be what this site is about without hearing any sarcasm or uninformed comments. It made my day, especially Cliff Ramsdell. Good pickup there.
    My comment would have mirrored HRP's
    Pat
  14. RichFox
    RichFox
    Another one with a dropped axle, reversed spring eyes and a flattened crossmember plus channeled. Down in front. IMG_2469[1].JPG
    Jet96 likes this.
  15. Sent from my iPad using The H.A.M.B. mobile app
