On my Willys wagon project I want to use a dropped axle in front to get it down. My question is with my Saginaw box mounted towards the front of the frame and the pitman arm facing to the rear , what problems will I face regarding tie rods and steering arms on the 37-48 spindles I plan on using? Will I need to use a tie rod/drag link setup for a cross steer setup and with the dropped axle where can I get matching dropped steering arms? I plan on running the tie rod setup between frame and springs. Any thoughts or ideas about what I'm planning would be appreciated. Bob
