Technical dropped tube axle position question
Discussion in 'The Hokey Ass Message Board' started by evobuilder, Nov 14, 2019.
  1. evobuilder
    evobuilder
    found the answer on how to set caster on a drop axle with hairpins - answered below - Thanks all!
  2. Needs to be 5 to 7 degrees leaned back.
  3. Happydaze
    Happydaze
    What you're describing is caster and the ballpark inclination has already been mentioned.
    But, split wishbones and a tube axle? Generally there's no flex in such a arrangement so there's likely breakage at the weakest link, wherever that may be.
    That's all said without the benefit of pics which are always helpful.
    Chris
  4. evobuilder
    evobuilder
    awesome thanks!
  5. evobuilder
    evobuilder
    You are correct - I meant hairpins and not split wishbones (too many projects going on).
