Technical Drum brake primary secondary
Discussion in 'Traditional Hot Rods' started by Abchoppers, Jun 10, 2023.
  1. Abchoppers
    Abchoppers
    Just installed all new drum brake pads, and learned about primary secondary pads the hard way.
    So the rears have an obvious primary and secondary, and I luckily put the big to the back so they should be good. The fronts however do not have a small lining and big lining, they are all the same length. They do however have 2 thick shoes and 2 thinner shoes. So I’m thinking I should just put the thicker material shoe towards the rear?
    Thank you in advance
    Ryan
    jimmy six likes this.
  2. 19Fordy
    19Fordy
    What year and make of vehicle are you describing?
  3. Abchoppers
    Abchoppers
    Sorry my apologies, 1956 mercury stock drum brakes
  4. Abchoppers
    Abchoppers
    After I looked closer there is a longer and shorter pad, so I installed big to the back. All good now
  5. bschwoeble
    bschwoeble
    Not being critical. Just trying to be informative. If you have drum brakes, then you have brake shoes. If you have disc brakes, then you have brake pads. Let the criticism begin.
  6. Nope, you are 100% correct. I have the same issue with my guys at work. I’m a stickler for correct terminology.
    bschwoeble and Abchoppers like this.
  7. Abchoppers
    Abchoppers
    Very true! No criticism from me
    bschwoeble likes this.
  8. BJR
    BJR
    Unless it's a Ford or any other car with the shoes held at the bottom with a bolt and not self energizing. Then the long shoe goes on the front.
    gimpyshotrods likes this.
  9. ClayMart
    ClayMart
    I don't know if I'd say that the trailing shoe contacts the drum first, but the anchor pin at the top of the backing plate prevents the trailing shoe from rotating with the drum when the brakes are applied.
    The following is quoted from the Hemmings.com website.
    "When the operator steps on the brake pedal, pressure applied by the hydraulic wheel cylinder pushes the upper parts of the shoes outward.
    The primary shoe wedges against the rotating drum while the drum tries to pull the shoe along with it. This self-energizing action pulls the shoe even more tightly against the drum, multiplying the braking force.
    As the primary shoe shifts inside the drum, its lower "foot" pushes against the adjuster, applying force to the secondary shoe and forcing it outward against the drum."
    More details at the link below.
    https://www.hemmings.com/stories/article/duo-servo-brakes
    For that matter, did a stock '56 Mercury use duo-servo, self-energizing brakes? :confused:
    X-cpe likes this.
  10. gimpyshotrods
    gimpyshotrods
    Same.
    bschwoeble and Truckdoctor Andy like this.
  11. 57 Fargo
    57 Fargo
    On servo acting brakes the primary or front or short shoe has a lighter return spring so it contacts the drum first which then apply the secondary or rear shoe…
    ClayMart and Truckdoctor Andy like this.
  12. Budget36
    Budget36
    I have never noticed thinner and thicker shoes, longer/shorter yes.
  13. Does that include Mopars ?
    Tommy
  14. BJR
    BJR
    If one end of each of the shoes are fastened to the backing plate and are not free for one shoe to push the other shoe, yes it applies to Mopars.
  15. 57 Fargo
    57 Fargo
    once upon a time the secondary shoes used to be thicker lining as they do most of the work. However I think that has mostly changed in the last few years
  16. Budget36
    Budget36
    Dang,,been changing shoes for a long time , never noticed it.
    Abchoppers likes this.
  17. Onemansjunk
    Onemansjunk
    from Modesto,CA
    You don't call cabbage - lettuce. You don't call a flex plate a flywheel.
  18. Budget36
    Budget36
  19. 57 Fargo
    57 Fargo
    Yet people constantly call core plugs frost plugs….
  20. Budget36
    Budget36
    And we all have motors in our vehicles;)
  21. Harmonic Balancer?
    Sadly, I would hazard you a guess that most of the guys I work with could not tell you the difference between primary and secondary hydraulic brake shoes. Granted, we deal with primarily air brakes and hydraulic disc brakes, but to me primary and secondary brake shoes are basic automotive theory, however, and this just occurred to me, how long has it been since the OE’s used self energizing drum brakes? I just realized I’m a dinosaur. All that being said, Little Truckdoctor will certainly know the difference in brake shoes and self energizing vs Huck style brakes. Our 3100 still has Huck style on it, for now.
    gimpyshotrods and Budget36 like this.
  22. gimpyshotrods
    gimpyshotrods
    Wiper and heater blower.
    Truckdoctor Andy and Budget36 like this.
  23. Abchoppers
    Abchoppers
    These were duralast brake shoes, the rear ones were same thickness all around but did have a definite longer and shorter shoe. The fronts, after I inspected them better, had a longer and shorter shoe but also the secondary shoes were about 1/8” thicker. I first put both secondary’s on one side, when I went to put the drums back on one side went too easy, the other very hard. That’s when I knew I did something wrong
  24. BJR
    BJR
    I would hope we have motors in our rides. Otherwise what do General Motors and the Ford Motor Company put in their cars for propulsion?
    Blues4U, Budget36 and Desoto291Hemi like this.
  25. Budget36
    Budget36
    But ya know what I meant;).
    Truckdoctor Andy likes this.
  26. 57 Fargo
    57 Fargo
    Have a look at the definition of motor…:)
    Blues4U and Budget36 like this.
  27. Budget36
    Budget36
    I just did. Lol. I’ll be darn!
    57 Fargo likes this.
  28. ClayMart
    ClayMart
    "You don't tug on Superman's cape.
    You don't spit into the wind.
    You don't pull the mask off that old Lone Ranger.
    And you don't mess around with Slim!"
    - Jim Croce
    427 sleeper likes this.
  29. TCTND
    TCTND
    Engine just means machine or mechanism, so all motors are engines but not all engines are motors.
  30. gimpyshotrods
    gimpyshotrods
    Wait to you hear that what you are using to read this is the modern version of a difference engine.
