1952-59 Ford Drum brake upgade
Discussion in 'Off Topic Hot Rods & Customs' started by ezrodder1, Apr 3, 2024.
  1. ezrodder1
    ezrodder1
    Working on the rear brakes on my 53 customline and noticed that the previous owner eliminated the parking brake levers. I saw the sticky about using the mustang brake shoes but did this also include using the parking brake hardware? I must have missed this reference somewhere. Does anyone know if using the mustang parking brake parts will work? Thanks Ezrodder1
  2. craigtone
    craigtone
    Yes, I replaced all of the guts with '67 Mustang parts and Kevlar Mustang pads.
    JeffB2 likes this.
  3. ezrodder1
    ezrodder1
    Cool! Thank you! Did you use the 53 parking brake cables or use the mustang ones?
  4. craigtone
    craigtone
    Kept the 53 cables
  5. ezrodder1
    ezrodder1
    Thanks again! Unfortunately PO cut my cables and I will have to find new ones or adapt something else.
  6. jimmy six
    jimmy six
    I don’t know about a 53 but by 55 there was only 2.One from the parking brake handle and a single cable to the rear drum shoes that had a loop over the adjustable part the one at the dash pulled on. I’ve included a parts view of the 55-56. IMG_0309.jpeg
  7. ezrodder1
    ezrodder1
    Yes the 53 is similar with 2 cables. One from hand brake to under car equalizer and one continuous cable that runs to each rear brake with a yoke loop at the equalizer rod. I found that inline tube in Shelby twp mich may have the longer cable. As it’s special order I will call and get more info. Thank you!
  8. ezrodder1
    ezrodder1
  9. JeffB2
    JeffB2
    from Phoenix,AZ
