drum brake
Discussion in 'The Hokey Ass Message Board' started by mark197508, Nov 1, 2012.
  1. mark197508
    mark197508
    from ohio
    what are they ? and are they worth anything? they look in good shape still on car drives an stops fine just going to disc because its going to be going to the drag strip alot when summer gets here
  2. Hnstray
    Hnstray
    from Quincy, IL
    Ford .......'48 or earlier. The red drum has a wheel adapter on it.
    Ray
  3. Ray is correct. If they don't adjust on the bottom they are post war. If there is an adjustment at the bottom they are pre war. The end of the spindle looks like someone torqued the nut real good (I bet they won't do that again). ***uming the drums are less than 12.060 the drums and backing plates should be worth a couple of hundred. Check the ads and see the current price. Add another few bucks for the adapter. Check the catalogues to see the current price.
    Charlie Stephens
  4. mark197508
    mark197508
    from ohio
    dont have dial caliper big enough .but tap measure right on 12 even. no adjuster at bottom. im new to these cars never work on anything older 66
  5. That makes them post war (which I prefer). Find someone with a drum mike so you know what you have and then advertise them here and on fordbarn.com.
    Charlie Stephens
  6. mark197508
    mark197508
    from ohio
    thanks alot.. ill take them to work the machine shop get them measured.
  7. Shaggy
    Shaggy
    from Sultan, WA
    Why do you need disks for the drag strip?? your going not stopping....
  8. mark197508
    mark197508
    from ohio
    in drag racing when you get in to round robin theirs not much time between runs no time for brakes to cool down im shooting for mid 11s
  9. chopt top kid
    chopt top kid
    Those are '40/'41 hubs and drums. I can't see the adjusters on the backing plates but I suspect they are the same. Postwar drums are mounted with the hub on the outside.
  10. how much do you want for them?
  11. Texas Webb
    Texas Webb
    The hub is on the inside.I payed $200 for turned drums w/ hubs,bearings, spare shoes all internals.
  12. mark197508
    mark197508
    from ohio
    sale pending .230 for everything drums shoes hubs backing plates hoses not many miles on them car was never been ***le since built only drive way an mile up an down road few dozen times
  13. mark197508
    mark197508
    from ohio
    an there is a chevy adapter on them
  14. mark197508
    mark197508
    from ohio
    drum set up still for sale make an offer. ups shipping $43 72lbs ready to ship
  15. 62rebel
    62rebel
    need to move this to the cl***ifieds. those are a nice set of brakes.
  16. mark197508
    mark197508
    from ohio
