Technical Drum brakes - lack of stopping power
Discussion in 'The Hokey Ass Message Board' started by Driver50x, Jan 18, 2023.
  1. Driver50x
    Driver50x
    My T-Bucket has been on the road for three years now. My one big complaint with it is the lack of rear brakes. I’ve been pulling my hair out and I’ve done everything I can think of to fix it. I cannot lock up the rear tires, even on the gr*** or loose gravel. If I am driving at 10-60 MPH and I pull on the parking brake lever as hard as I can, the car just barely, barely slows down. The car stops well on dry pavement, but very poorly on wet pavement or gravel. The rear end and brakes are from a 1979 Chevy Malibu. I built the car with a new master cylinder and wheel cylinders, and I have since replaced them again to make sure that was not the problem. I installed a pressure gauge on the rear brake system, and I can easily get it over 1000 PSI, so I don’t think that is the problem. At first I had the drums machined, and then I put a new one on with no change in braking. I have tried four different brands of brake shoes, including NAPA and AC Delco. They all act the same, even after a 500 mile break in period, and the contact pattern looks pretty decent on them. The only thing I can think of is that the brake lining material is somehow too hard or does not have enough friction?? I do know that in recent years they have removed asbestos and copper from brake shoes. What else can I be missing?! I used NAPA shoes on the front drum brakes, and those work fine.
  2. alanp561
    alanp561
    These are self adjusters, no offense but, are they installed correctly? Pics would help here. How are you adjusting the rears initially? Is there a proportion valve in the system?
    dana barlow likes this.
  3. 57 Fargo
    57 Fargo
    1000 psi is enough to lock up the rear brakes on something like a t bucket. Pictures with the drum off would maybe help. Because the park brake and the service brakes are both ****py it leads me to believe it’s an ***embly or adjustment issue.
  4. Driver50x
    Driver50x
    I adjust the self adjusters out until there is a slight amount of drag on the drum/wheel tire ***embly. I’m out on the road and can’t take pictures today. I will when I get home.
    1971BB427 likes this.
  5. Driver50x
    Driver50x
    There is no proportioning valve.
  6. alanp561
    alanp561
    Try adjusting them out until the shoes are in full contact with the drums and you can't move the wheels. Back them off until they turn easily and then tighten until there is a very slight drag. Just enough that you can hear a whisper of contact. It's time consuming but it works.
    Tow Truck Tom and VANDENPLAS like this.
  7. 40FORDPU
    40FORDPU
    Now obvious, throwing new parts at it is not solving the problem.
    Time to visit the mechanics/operation of the system.
    Wheel cylinders need brake fluid to push the wheel cylinder pistons out..why aren't they getting the required brake fluid/pressure to do that?
    I'd be looking hard at the brake master cylinder push rod/pedal adjustment, residual pressure valve/s, or proportioning valve, if none exists..research a proper drum/drum system, and duplicate it.
    studebaker46 likes this.
  8. squirrel
    I wonder if the rear wheel cylinders are just too small? ***uming the car is the one in your avatar, the weight balance is quite different than the car that the rear brakes were designed for.
    As for the parking brake...without knowing what kind of leverage it has, it's hard to say why it's not working right.
  9. my experience with drums are limited, but its always seemed that auto adjusters do a worse job than manual adjusters, just in general.
  10. That has not been my experience. Automatic adjusters should keep the brakes adjusted well. They adjust when the brakes are applied when backing.
    Ben
    Crazy Steve, hrm2k and FishFry like this.
  11. Tim
    Tim
    from KCMO
    Curious as well. Photos will help a ton.
    Is the master located on the firewall or under the floor?
  12. FishFry
    FishFry
    A friend had the same problem - turned out that the shoes where installed backwards, so they where not "self energizing".
    Frank
  13. Rocky
    Rocky
    Classified Editor
    That's what I was thinking......short shoe to the front, long shoe to the back
  14. BJR
    BJR
    You may have a master cylinder without residual pressure valves in it. That would let air into the rear wheel cylinders. You could remove the line on the master from the rear brakes and see if the valve is in there.
    Tow Truck Tom likes this.
  15. Driver50x
    Driver50x
    now that is a great idea. I had ***umed it was one problem. Maybe in fact it has two separate problems.
  16. Tim
    Tim
    from KCMO
    The shoes being swapped would explain the hand brake not working and the pedal not working where the wheel cylinder size wouldn’t effect the mechanical brake.
    Roothawg and Illustrious Hector like this.
  17. V8 Bob
    V8 Bob
    Normally the brakes become aggressive when the secondary shoe is installed as a primary on duo-servo drums.
    Hard to figure lousy rear braking with a mid sized axle, 1000 psi, on a very light car! Some pictures may be helpful, especially plumbing, M/C and wheel cyl. bore sizes.
    Grimpala and 57 Fargo like this.
  18. pprather
    pprather
    What size master cylinder bore are you using?
    I'd start with wheel cylinders that are the same bore as the master.
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    I remember an inherent problem with those vintage brakes. The wheel cylinders clip into the backing plates and had a tendency to wear and then the wheel cylinders would turn and not push straight to the shoes, the salvage yard I used to work at sold new replacement backing plates (lots of them cuz it was a big problem) that would hold the wheel cylinders level, I believe there was also some kind of clamp that was a band-aid fix too... don't know if this is your problem but it was a terrible design
    ffr1222k, 2Blue2, ClayMart and 2 others like this.
  20. FishFry
    FishFry
    That wouldn't do anything to the emergency brake - that's why my money is on reversed shoes.
    ski likes this.
  21. BJR
    BJR
    Could be more than one thing wrong here though.
  22. Driver50x
    Driver50x
    I am using a Wilwood 10 psi residual pressure valve. I have the shoes with the longer brake linings (the secondary shoes) on the rear.
  23. Driver50x
    Driver50x
    Yes I do have those el cheapo style of backing plates and wheel cylinders. I was wondering if that could somehow be the problem.
  24. gimpyshotrods
    gimpyshotrods
    What is the bore of your master cylinder?
    Are the rear wheel cylinders held on with bolts, or an annoying round clip?
  25. jaracer
    jaracer
    How do the shoes fit the drums? If you put a shoe in the drum it should touch in the middle of the shoe with about 0.002 clearance on each end. They deform slightly on application to give full lining contact.
    Also, it has been my experience that most people adjust brakes with self adjusters too loose on the initial adjustment. They should have a bit more than a slight drag on initial adjustment. Most adjust to slightly dragging at one point on a revolution. There should be a slight drag all the way around.
    alanp561 likes this.
  26. gimpyshotrods
    gimpyshotrods
    If you do have the clip on wheel cylinders, than @moriarty probably nailed it.
    Pull one brake ***embly apart. Unclip the wheel cylinder, and see if it wiggles or rocks in the hole that it it is in.
    If it does, replace the backing plates.
    DORMAN 924220, at the auto parts store of your choice, or online. I believe that's the part number for the pair.
  27. squirrel
    Then you still have to figure out the parking brake....
    Driver50x likes this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    those backing plates were a huge problem back then....
  29. Driver50x
    Driver50x
    The master cylinder bore is .937 inches. Yes, I have those annoying clip on wheel cylinders.
    gimpyshotrods likes this.
  30. jjjmm56
    jjjmm56
    from FL.
    Have you replaced the rubber line going to the rear ? If the line is collapsed it will still give you pressure but no flow.
    s55mercury66 likes this.
