Technical Drum brakes stuck on
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, Apr 7, 2023.
  1. Harleyv89
    Harleyv89
    Hi,
    my front drivers side brake is stuck partially on. Drum brakes and it is a 1963 chevrolet impala RHD. i took the wheel off and turned the drum it grabs pretty harsh in the same spot.
    thinkin the return spring could be weak? any suggestions would be great.
    thanks
  2. squirrel
    If the drum rotates part way and then it grabs, the drum is out of round, for one thing....might see if you can get the drum turned and see how it does. Be sure to measure diameter first and see if it's still useable, they didn't publish specs back then but I'd not try to get it turned if it's bigger than 11.060" now, and not use it at all if it's bigger than 11.090"
  3. I had a shoe that came un glued that grabbed
  4. i7083
    i7083
    I had a shoe that grabbed and I came unglued.
    Dino 64, jimmy six, 1952henry and 5 others like this.
  5. Beanscoot
    Beanscoot
    I had a shoe that got leaked on by a little brake fluid and it grabbed like heck.
    And I still haven't figured out what side of the car you mean. Why don't people just say "left front" or "right front"?
  6. Ebbsspeed
    Ebbsspeed
    Another cause for it to be grabbing the same spot could be rust on the inside of the drum.
  7. Tim
    Tim
    from KCMO
    Beanscoot likes this.
  8. Happydaze
    Happydaze
    Is this a driven car or something that's been parked up? It can have a bearing (no pun intended).
    Chris
  9. Budget36
    Budget36
    Could be a wheel cylinder or an old deteriorated brake line to it keeping the brakes partially engaged.
  10. F-ONE
    F-ONE
    from Alabama
    Check the backing plates!!!!
    The backing plates have pads that the edge shoes slide on and these should be greased. Most owners never greased these and over the years the edge of the shoe would wear a groove due to vibration. Eventually these grooves will catch the shoe causing it to "stick". The solution is to file/polish the grooves smooth if lightly grooved or weld up the grooves and restore the pad surface if the damage is severe.
    Budget36 likes this.
  11. BJR
    BJR
    A bad rubber brake hose will keep a brake from releasing.
    3quarter32, nosford and indyjps like this.
  12. indyjps
    indyjps
    If you're unfamiliar with drum brakes, check out a shop manual or youtube. Here's a pic of 63 vette front drums, the parts and layout should be same
    I agree with comments above, wheel cylinder / brake hose / brake ***y locking up due to corrosion / warped drum/ damaged shoe. Lot to chase down. Learn about these brake systems to identify it.
    If it just started happening - you know the right parts are there. If you just got the car - don't trust the previous mechanic:D
    ClayMart likes this.
  13. 1ton
    1ton
    I'm going with the rubber brake hose. replace it.
    Hollywood-East likes this.
  14. RICH B
    RICH B
    That's a pretty broad question, why not go one step further and pull the drum and see what's going on inside.
  15. ClayMart
    ClayMart
    Try disconnecting or at least loosening the brake hose at the wheel cylinder on the offending wheel. If the hose has failed, this should release any trapped pressure to the wheel cylinder.
    BJR likes this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Old flexible brake hoses can collapse under pressure and when the brake pedal is released the hose can still holds pressure, I they have never been replaced they are 60 years old. HRP
    BJR likes this.
  17. Hollywood-East
    Hollywood-East
    As several above have said, Rubber hose's break down over age, Think harding of the arteries...
    Free up, spin fine, Hit pedal, No turn..
    Cha-Ching, you'll know
    BJR likes this.
  18. Rich B ,
    That’s a really funny question,,,,!
    This is the same guy that asked about his transmission not shifting correctly .
    His linkage was hanging down out if sorts,,,,,but he wouldn’t climb under the car to investigate,,,,that went on for two months,,,,lol .
    This brake drum will be 6 weeks at least !
    Tommy
  19. Beanscoot
    Beanscoot
    Hey, I also live in Victoria so I can go take a look...
    Oops, wrong Victoria, I'm in Canada.
    Desoto291Hemi likes this.
