Dual chamber master cylinder?
Discussion in 'The Hokey Ass Message Board' started by 36tudordeluxe, Aug 30, 2013.
  1. 36tudordeluxe
    36tudordeluxe
    Am running drum/disc combo., the larger chamber is in front of the master cylinder, this is the chamber that should feed the front discs, correct?
  2. NH Gearhead
    NH Gearhead
  3. 36tudordeluxe
    36tudordeluxe
  4. gimpyshotrods
    gimpyshotrods
    The larger chamber is for the discs, but it is NOT always in the front.
  5. GregCon
    GregCon
    from Houston
    Huh? I think the front chamber is for the rear brakes. I guess it depends whose master cylinder you are running.
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    There are drum/drum masters available from any parts house which have two equal capacity reservoirs.
    The larger chamber, whether front or rear, on a disc/drum cylinder feeds the front disc brakes.
  7. gimpyshotrods
    gimpyshotrods
    With a disc/drum setup, if the chambers are different sizes, the large one is always for the discs. It is not always in the front.
  8. HOTRODPRIMER
    HOTRODPRIMER
    Yes. HRP
  9. V8 Bob
    V8 Bob
    Big kudos to you and gimpys for the pictures and facts about the primary disc/drum chamber not always going to the fronts, something I've had many discussions :rolleyes: about over the years with many "disbelievers". :cool:
  10. 1971BB427
    1971BB427
    from Oregon
    It does, as some have the larger chamber in the rear, while others it's up front. Whichever is larger is front brakes, even in a drum/drum setup.
