Technical Dual Four Installation
Discussion in 'The Hokey Ass Message Board' started by Crayons, Dec 23, 2025.
  1. Crayons
    Crayons
    I intend to install this dual four setup on my 327/300 hp Ford with Turbo 350.
    My guestion is, where do I draw vacuum for the turbo 350 and vacuum advance for distributor. The carbs are Holley 3720SB.
    There are ports on the front and back. Big in back, small in front. Are these okay to draw from. In addition, im utilizing a vented oil cap in the oil filler. Is that good enough for "crank case ventilation" ?
    Deuces likes this.
  2. wheeltramp brian
    wheeltramp brian
    Those are not holley carbs ,there carters. You can use the vacuum port off of the rear for the trans
    bchctybob, Crayons and Deuces like this.
  3. swade41
    swade41
    from Buffalo,NY
    I have Carter Compition 600's on the same intake, I use the front vacuum port on each carb, one for trans and the other carb for distributor.
    mad mikey, bchctybob and Deuces like this.
  4. Kerrynzl
    Kerrynzl
    I just want to see that intake bolted onto a Ford! [post photos please]
    y'sguy, Blues4U, hrm2k and 8 others like this.
  5. Mr48chev
    Well I'll be nice to another old fart from the PNW.
    It doesn't make any difference in what ch***is or body and engine is in as when you are working on an engine you are only concerned with that engine and not the body or ch***is it is in.
    Still without checking out how long you had been here and that you are 77 and have a 51 Ford you had me wondering if you were a troll from some other group when you said that your Edelbrock carbs were Holley. That's a lot of carb for a 327 unless it has the cam and goodies to handle it though.
  6. big duece
    big duece
    from kansas
    You could use the road draft port near the distributor with a pcv line to the carb base, along with the breather in the oil fill tube. Your engine with stay cleaner longer. There is a casting boss below the rear carb you could drill and tap for trans vacuum. [​IMG]
  7. DDDenny
    What model Ford had a 327?
    Adriatic Machine and SS327 like this.
  8. 19Eddy30
    19Eddy30
    from VA
    I was mistaken,, 1963/64 B-D
    thought sbc , the information say's with a Pontiac engine with 6 stromberg's
    :D:D:D
    We know what Op ment ,Ford
    Holley- Carter that questionable
    Seem's just new to Hobby
    or testing !
    Deuces likes this.
  9. lostn51
    lostn51
    from Tennessee
    Hell now I’m really confused o_O
  10. CSPIDY
    CSPIDY
    I see you running a pvc, for it to work properly the vented cap should be piped to the intake, no?
    hrm2k likes this.
  11. CSPIDY
    CSPIDY
    Too many, although they are great engines in their own right
    Deuces likes this.
  12. swade41
    swade41
    from Buffalo,NY
    If you only have the single breather in the fill tube you'll need the pcv in the old road draft tube location hooked to the big port on back of carb.
    Crayons, big duece and Moriarity like this.
  13. Crayons
    Crayons
    Evidently I was too....Carters not Holley, and a 327 IN a Ford.
    Tim and bchctybob like this.
  14. Crayons
    Crayons
    Alright, I left out the phase "in a"...
    It's 327 in a Ford. The carbs ARE Carters.
    bchctybob and Kerrynzl like this.
  15. seb fontana
    seb fontana
    from ct
    Just my opinion but if the 327 is a good running engine it should move the Ford right along. If you want more "go" the dual 4v might get you some, or more bling for sure, but might be shooting self in foot.
  16. jimmy six
    jimmy six
    First I’ve been running dual quads for almost 10 years on a relatively stock engine. Mine are set progressive linkage like all 245/270 hp SBC’s. I don’t know what the internal porting design of an Offenhauser but I installed my PCV system between the carbs using a V100 valve that was stock for the era at the back of the carbs If your block has the stock oil separator in the lifter valley with a fitting available from on of the “stock parts” sellers. You could run it off either carb if it is a primary one. If needed there is a fill tube that is sealed with a screw in PVC valve used on the early Z28’s.
    300hp 327’s in 62/64 used single Carters so using 2 properly jetted will perform and run fine. The trans modulator needs engine vacuum and vacuum can on the distributor “can” use either Venturi or engine. Mine happens torun and idle better on venturi. Good luck.
  17. DDDenny
    As do the L79/327's.
    Deuces and jimmy six like this.
  18. bchctybob
    bchctybob
    I kinda figured what you were getting at. That setup will look great on your 327, should run fine if set up right. It looks like a very clean swap meet find, do you know the history of the carbs? Were they professionally rebuilt? Are they both 3720sb? I would check to see that they both have the stock jets and metering rods, first thing. Verify that the float settings are correct. Check the idle mixture screws to be sure that they are the same and adjust them equally to 1 1/2 - 2 turns out. Then you have a good chance of it starting and running and a good baseline to tune from. Others have addressed the vacuum question, Good luck.
  19. 57Fury440
    57Fury440
    My '57 318 came from the factory with dual Carter four barrels. They were small carbs, and I believe they were only 325 cfm each. With an Isky cam and headers it ran real nice. Do you know what cfm the carbs are?
  20. jimmy six
    jimmy six
    Where did the above L79 get its “flowthru” air for the PVC system. They had sealed rocker covers up until GM choose to put a breather oil separator in the cover.
    KoolKat-57 and Blues4U like this.
  21. big duece
    big duece
    from kansas
    Vent tube #29755 comes off road draft tube, to the underside of air cleaner.
  22. DDDenny
    Deuces, Blues4U, bchctybob and 2 others like this.
  23. carbking
    carbking
    Carter 3720sb flowed approximately 675 CFM each.
    Good luck.
    Jon
    Deuces, bchctybob and kadillackid like this.
  24. swade41
    swade41
    from Buffalo,NY
    That Offenhauser intake does not like progressive linkage, it's one open plenum directly under the carbs. It works pretty much like a front to rear divide, the back 4 cylinders pull from the back carb and front 4 from the front carb.
    18 yrs ago when I first started running that intake I did progressive linkage. The first time I pulled the plugs to check the tune I was horrified, front four plugs were white as a ghost ! I instantly dropped a pit into my stomach, I have no idea how that engine stayed together.
    I switched to 1-1 linkage and all plugs read pretty even to this date.
    I agree with making sure the carbs are stock and equal settings as a starting point, don't be surprised if you need to run the mixture screws in to a 3/4 turn, 2x4's tune differently than a single.
    Tim, 57Fury440, carbking and 5 others like this.
  25. Crayons
    Crayons
    Thanks for the information Jimmy.
  26. Deuces
    Deuces
    I have that kit....:D;)
  27. jimmy six
    jimmy six
    If the Offy has an open single plenum under the carbs then it’s best run the carbs connected straight up. I would also invest in a unisyn. For 4 barrels I mounted mine on an aluminum carb cover. Both are available from Summit. image.jpg
    warbird1, VI Lonewolf, Tim and 2 others like this.
  28. Blues4U
    Blues4U
    from So Cal
    I run dual four's on an Offy 360 manifold with progressive linkage and it works great, no problem with fuel distribution to the cylinders, and it runs fantastic.
    31 B'ville and jimmy six like this.
