dual fours
Discussion in 'The Hokey Ass Message Board' started by burt21, Jan 20, 2012.
  1. burt21
    burt21
    I am in the process of making a dual four scoop and nned the demensions from center to center for dual fours.I know manifolds are diffrent I have came across one that was 6 1/2 inches center to center and my hemi is 8 1/2 inches center to center. Can you guys give me some measurements on yours. you wont be disappointed in what i am making. thanks for all the help.
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Not sure what you are asking. You say yours is 8.5 inches, isn't that the dimension you need? My sbf is 6.5 inches.
    Don
  3. My Offy Dual Quad on my BB Mopar is 8.75" between centers
  4. Sounds like you need to set yours up and measure before you start cutting?
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    My Austin dual quad on my flathead is 8.25" center to center
  6. Moneymaker
    Moneymaker
    Customer's FE big block Ford on a engine stand is 8.5 center to center
  7. iammarvin
    iammarvin
    from Tulare, Ca
    My 331 Cad Nicson is 9 1/8" tween centers.[​IMG]
  8. burt21
    burt21
    Thanks alot for all the answers. What I want to do is make it so it will fit just about all the dual quad manifolds. It will look kind of like the old homes moody scoops for two fours. Thanks "RICHIES"
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Sounds like you are going to incorporate an adjustable plate so you can slide it closer and further to fit a variety of engines. Neat. Pictures when you are done will be great to see.
    Don
  10. movin/on
    movin/on
    FE Low Riser as previously stated 8.5"
    FE High Riser 9.25"
    For info only FE 3X2 10.5"
    Movin/on
  11. carbking
    carbking
    If you are trying to do a "one fits all", remember that in addition to carburetor spacing, there are several different air intake diameters on different carburetors.
    Good luck with your project.
    Jon.
