Technical Dual Holley 94 Question.
Discussion in 'Traditional Hot Rods' started by jayg48anglia, Feb 7, 2024.
  1. jayg48anglia
    jayg48anglia
    Is anyone out there running dual 94's on their banger? My motor is well built and has one 94 on it now. I know some are using 97's and 81's but I would like to run the 94's. THX. Jay
  2. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I have two 59s that will be going on my OHV setup, but have not installed or ran them yet.
    Some suggestions right off the bat from my research, make sure you install the anti-backfire check valves so you don't blow your power valves out in the event of a backfire though the carb. A good starting point for jetting is probably 2 sizes down from stock (51, IIRC) and you should pull your manifold vacuum and size the power valves based on that (probably in the 3"-5" range). Of course, do not block off the vacuum as some people do.
    jayg48anglia and Deuces like this.
