Dual Holley snipers on a flathead?
Discussion in 'Off Topic Hot Rods & Customs' started by ActionYobbo, Nov 3, 2025.
  1. 19Eddy30
    19Eddy30
    from VA
    @Mike Lawless
    In my previous post is One ecu piggyback second TBI Housing.
    Fuel Only .....
    Then another way of running Two
    TPI with ECU's each thinking it's
    a 4 cylinder.
    I deal with a tech / research and development that I can communicate with that we talk out side
    Of how its designed for common use for a Bolt on consumer / user,
    The second 1100 you would not use ECU @ all when I say piggyback ,
    It would be gutted , the only thing used
    Would be injector wiring piggyback to main Ecu in the one that is main , both TPI with internal regulator's
    Removed , Using One external
    Fuel regulator, one fuel line to
    connect / bridge both TBI housing .
    This is where laptop tunning is used
    To adjust program fuel pressure requirement & changing duty value
    The Ecu does not know 2 injectors
    Thinking One . This is done because
    Its 100pd injector if you would leave @
    The 60ish psi with 2 injectors , one in each TPI , the duty cycle would be like 20-30% may be lower. Fuel puddling.
    So lowering fuel pressure down 30ish psi in program adjust duty cycle to 65-75 % injector ,
    Less fuel & speeding up duty makes it more steady efficient .
    Mike Lawless likes this.
  2. ekimneirbo
    ekimneirbo
    from Brooks Ky
    The Holley Dominator EFI will control two throttle bodies at the same time, but it isn't cheap and I don't know if it would work with single throttle bodies.........but if you want two TBs then its better to have one controller. Might call their tech line and ask.
    FI Tech also has the means to control 2 throttle bodies but I don't know anything about them. Saw a Camaro at the Street Rod Nats that drove up from Tennessee and had one. Guy seemed happy with it.
    Here is a slightly older book where a guy converted his to two throttle bodies and a supercharger and its a good read. Look for it on Amazon. He steps you thru his problems.
    EFI Conversions by Tony Candella
    Here are a couple pages
    Anyway it will give you some food for thought hopefully............
    This is for older Holley stuff and you may be able to use OEM throttle bodies of some kind on your flathead, like something from a later model Ranger with a 4 cyl engine driven by Holley software. Don't know if thats doable but again something to check in to. :)
  3. Bandit Billy
    Bandit Billy
    ekimneirbo and 19Eddy30 like this.
  4. Bandit Billy
    Bandit Billy
    So, these EFI units are designed to work in tandem like the OP wishes. With a little detailing and creativity, I could make those look a bit more legit. 203 CFM per unit if I read that correctly.
  5. 19Eddy30
    19Eddy30
    from VA
    No originally Op want's left and right to be independent
    Twin 4 cyl , 2 Ecu witch wound be 2 of all ,etc.
    Bandit Billy likes this.
  6. Bandit Billy
    Bandit Billy
    Oh, well how the hell is that going to work? So, it could run as a 4 cylinder? I know Austin Martin has a 12 cylinder that they claim can shut down one bank of cylinders while the catalytic converters cool on that side, and then switch banks again. Obviously just a cruising, freeway thing to save gas. So, I guess it can be done. I missed that part of the project parameters.
  7. RodStRace
    RodStRace
    The exotics from Italy tend to do that, separate controls for each bank. Fuel, timing and sensors.
    The Viper used a 8 cylinder control and a piggyback 2 cylinder control. o_O
    This could be done, it's just is going to be a lot of effort for a pretty offbeat result.
    You have single 2 bbl intakes, dual inline 2bbl intakes, all the way up to Hilborn based EFI.
    https://myflatheadford.com/hilborn-fuel-injection-intake/
    If the entire reasoning is to run each bank separately, that last one could be set up to 'shut off' each bank (fuel and ignition) on command, provided the controller also handles spark. Ford used to have a cylinder balance test built into the OBDI software. So long as the lower end can handle the uneven power pulses, it would require a higher RPM to keep running. A heavy flywheel would probably be a useful addition.
    Again, I'm not trying to dump on OP's 'What If'. I am simply saying it's a lot of resources to achieve a rather esoteric result. Airplane engines have been designed to run upside down. I'd imagine that with enough work, a flathead could too, with a ton of effort concentrated on the oiling along with intake and cooling.
    https://www.jalopyjournal.com/forum/threads/flying-flatheads.1008972/
  8. mustangsix
    mustangsix
    Two single bbl throttle bodies and enough fuel for 250hp. Trying to do something as simple as this using a pair of Snipers is really pounding on that square peg. Especially the ideas of trying to divide the engine into a pair of four bangers.
    Two 50mm throttle bodies, two 60lb injectors, TPS, a MAP sensor, and a coolant sensor will be enough to get a Microsquirt working well. Crank signal comes from the ignition. No crank or cam wheels needed. Add a pump, regulator, and a return line. It's not that hard.
    Here's one guy's take on how to do it. He's going turbo, but the EFI system wouldn't be any different:
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    @ActionYobbo quote:
    Yeah the idea was 2 separate systems. Each sniper controlling a bank of 4 cylinders unaware that there is also another 4 attached at the crank. The trigger wire from the coil would need to go to both.
    Reply:
    Operating any single V8 engine with separate and independent controls for each bank would seem to create unnecessary problems. Co-ordination needs to happen so that the results aren't continuously fighting one another. Don't forget that they are still mechanically dependent on each other.
    If one bank is having a lean condition and is detonating while the other bank is running fine........what do the 2 independent computers do next? I don't see any benefit to be derived from a system like that.
    19Eddy30 likes this.
  10. Cgrgrspt10
    Cgrgrspt10
    This guy was at the All Ford Day this summer in Denver
    ekimneirbo likes this.
  11. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Great pictures, love to see that kind of innovation !:)
    Did you get to hear it run ?
  12. Cgrgrspt10
    Cgrgrspt10
    I hung out but never met the owner. I liked the way he did the coil packs in the firewall, no distributor. Must be all triggered electronically.
