Technical Dual Master Cylinder Conversion 1939 Ford Tudor
Discussion in 'The Hokey Ass Message Board' started by LongT, Aug 16, 2018.
  1. LongT
    LongT
    I am trying to put a dual mastercylinder in my 39 Tudor. I see lots of adapters for this and they all look the same so I know I am not the first.
    If you have done this how did you deal with the lack of clearance for the port closest to the mount. I only measure about 1 1/2 inches. I can't bend the tubing that tight. 20180816_173914.jpg PM
  2. woodiewagon46
    woodiewagon46
    from New York
    Try Godman Hi-Performance, 901-382-7404, they might have a 90 degree fitting you can use.
  3. Pete Eastwood
    Pete Eastwood
    from california
    Hole saw a hole in the frame, & run the tube straight out
  4. LongT
    LongT
    I was thinking banjo bolt. I've only seen them with AN fittings. I guess that is OK.
  5. LongT
    LongT
    Trans mount is on the other side of the x-member.
  6. LongT
    LongT
    I think I see what you mean. Since that is the x-member, on an angle, a hole may give enough room. Have to check.
    Bill
  7. seb fontana
    seb fontana
    from ct
    You can make this bender, or by filing a groove in a piece of wood dowel.. PIC_1058.JPG PIC_1054.JPG
    LongT likes this.
  8. BJR
    BJR
    What are the grooved round parts from?
  9. Terrible80
    Terrible80
  10. woodscaper
    woodscaper
  11. LongT
    LongT
