Dual master on Drum/Drum set up. I have Q's.
Discussion in 'The Hokey Ass Message Board' started by KCsledz, May 5, 2006.
  1. KCsledz
    KCsledz
    Just trying to figure out what other parts I need to collect for a drum/drum set up on a 57 chevy.
    I found a dual master w/o booster that should bolt right up. What else do I neet to round up for the conversion?
    Proportioning valve?
    New tee's and line?
    Anyone with a brake line schematic I could look at?
    Thanks!
  2. Tudor
    Tudor
    from GA
    www.mpbrakes.com has great brake system schematics
    it looks like you have to login now - that is weird
  3. 51 MERC-CT
    51 MERC-CT
    No prop. valve needed on drum/drum. If master cyl. doesn't have built in residual valves, then you need two 10lb. valves.
  4. KCsledz
    KCsledz
    The master is from a 68 Chevelle. I will have to check on the valves. I was told by someone elso who used one on their 55 that it bolts right up and works great for them.
    I am going to a junk yard next weekend to try and find some good brake lines and fittings off of a full size chevy truck or something of that nature.
    Unless someone has a better alternative vehicle they could recommend.
  5. sideshow01
    sideshow01
    from Dirty Jerz
    Take the cylinder into your local NAPA... Chances are you'll have to spend a few minutes rustling through the weatherhead bin. On my Buick I needed reducers, a couple tee's a few block-offs for the junction block and a straight line-to-line fitting.
    -B
  6. krylon32
    krylon32
    from Nebraska
    You don't need check valves if you are mounting it on the firewall
  7. Tudor
    Tudor
    from GA
    Please do a search on Brakes - C9 has done some outstanding tech posts telling you everything you'll need to consider.
    First thing you need to do is identify the master cylinder bore and confirm it was for a drum drum set up. 68 chevell may have had disc drum by then - I am not sure. I would also consider not using brake lines out of a junk yard. The fluid may be compromised (absorbed water) and the inside of the lines may be rusted.
    You can either make them or I am sure someone may have a kit for a 57 chevy 4 door.
    If you get plain steel lines they should not be that expensive.
    Do it once - do it right and you won't have to fool with it all the time.
  8. 53sled
    53sled
    from KCMO
    Get plenty of "extra" line and connectors. Rent the double flare tool and take back what you don't use
  9. KCsledz
    KCsledz
    Great thanks! The chevelle had both in 68. Drum/drum and disk/drum set ups.
  10. Hmmmm I have issues:D
  11. KCsledz
    KCsledz
    Thats a better idea than what I was thinking.
  12. caffeine
    caffeine
    from Central NJ
    i guess i'll hijack away while Bttt....how about if your running a booster, do you need and prop, or residual valves?
    can someone explain what the prop, and res, valves purpose is?
    also, what size brake line and fittings should be run on a boosted 2 res setup. with drum/drum
  13. 3034
    3034
    The proportioning valve regulates the amount of braking power to the back brakes in relation to the fronts. You don't want the rears to lock up while the fronts are only lightly braking. An adjustable prop valve allows you to fine tune this.
    The residual pressure valves are used to keep brake fluid from draining out of the wheel cylinders when your master is mounted lower than they (wheel cylinders or calipers) are. Use a 10 lb. on drums and a 2 lb on disks. 3/16" lines should be fine.
  14. 53sled
    53sled
    from KCMO
    since the m/c is ABOVE the drums, you don't really NEED res.pressure, and the wheel cylinders are all the same, so you don't NEED a prop. valve. They can/will make the brakes perform better, but it is still drum/drum.
  15. tunglegubbin
    tunglegubbin
    No!
    A 2lbs valve is needed for disc brake application where the main cylinder reservoir is lower the the bracke caliper. Otherwise you don't need it.
    A 10lbs valve is always needed where you have cup seals due to their design.
    Cup seals is used in the wheel cylinders of drum brakes.
  16. tunglegubbin
    tunglegubbin
    ...and OEM master cylinders for drum brakes often have the residual valves built into them.
  17. Hellfish
    Hellfish
    I have a 67 MC on a 63 booster mounted on teh firewall of my 59. No extra valves. It works great.
    Are you INSANE?!? Why would you go through the trouble of pulling old, and possibly damaged, brakes lines when you could get them new, bend them yourself, save time, and be safe?!?!?
  18. caffeine
    caffeine
    from Central NJ
    how do you check if your master has residula valves in them? its one of those street rodder, gold chainer standard master/booster/pedal/bracket bolt on setups.
  19. KCsledz
    KCsledz
    You should have read on. Going with new line and renting a flair tool. Junk yard would have been for fittings not line.
  20. Hellfish
    Hellfish
    my bad! but you did say you were going for "lines and fittings" :p
