Hot Rods Dual point distributor, or Pertronix conversion?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Aug 13, 2021.
  1. 57 Fargo
    57 Fargo
    I typically just use what the car came with. My Chrysler has points, the Fargo has the factory Chrysler electronic ignition because that was the distributor that was in the engine that went in it.
    Blues4U likes this.
  2. sunbeam
    sunbeam
    I guess I'm cheap you can spend $200+ on a MSD or $30 on a 70s Chrysler module and do the same thing on most applications. Also fixs the I can't find a good condenser issue[​IMG]
  3. Truckedup
    Truckedup
    Dual points are to increase dwell time....They are not needed when using points to trigger an electronic module or MSD type control box...
    I used the stock but recurved points distributer on my modified 302 GMC street engine with dual points, then single points with a Mallory 6A multi spark CDI and finally a small cap HEI .All the systems did the job but the HEI could fire a larger plug gap allowing a leaner part throttle fuel mixture ...
    Cosmo49, Blues4U and loudbang like this.
  4. Rand Man
    Rand Man
    I had problems with the duel point Mallory on my 327. Petronix really woke it up.
  5. I forgut to Tell some of you What I meant when I Said Needle Point
    its the Type of Bearing's that the Distributer has, Most use Babbit
    Bearings, This gives you a little more Rev. time with the Dizzy
    it comes with a 12 degree in the Dizzy.
    Just my 3.5 cents
    LIve Learn & Die a Fool
  6. Cosmo49
    Cosmo49
    I've run a large cap HEI bought second hand and had the ONLY misfortune of a module going bad on a dark and rural country road (cue rainstorm or snow or wind or something) in over 120 k miles of driving. Had I kept a module with me (a ten minute job even if I stopped to light one up) the volunteer fireman going in for his overnight shift wouldn't have been troubled by giving me a ride to the station's telephone.
    As above I attribute (Red highlight) the HEI and larger plug gap with giving me mid 17-18 mpg in a 49 half ton, '56 235, now with 120 k carefully driven miles.
    impala4speed and Blues4U like this.
