Technical Dual Quad hard line kits
Discussion in 'Traditional Hot Rods' started by The HellyDid, Aug 29, 2021.
  1. The HellyDid
    The HellyDid
    from Florida
    Anyone make a nice pre bent hard fuel line kit for a pair of Carter AFB carbs with all the fittings for the shorter (close carbs) Edelbrock intake, don't know if I can choke down a -6 line kit quite yet.
  2. jimmy six
    jimmy six
    Get a tight bender from Eastwood, 5/16” line and fittings and make your own. I like using a gl*** bowl filter too. If my fuel pump was on the SBC side I would have done my Y a little different. Make all peace out of coat hangers first. Add fittings and flare first then bend. Making a few mistakes is ok.
  3. Bob Lowry
    Bob Lowry
    Wouldn't the SBC early Corvette dual quad fuel lines with gl*** bowl filter work? The dual quad 409's had
    a similar set up. I have always used the snowflake dual quad intakes, so I might not understand that the Edelbrock
    intake has different spacing between the front and rear carb.
    -Brent- and Deuces like this.
  4. The HellyDid
    The HellyDid
    from Florida
    413bigblock.jpg I already have the gl*** filter like the one above, didn't think about one for the small blocks, should work, I'll have to check that out.
  5. Bob Lowry
    Bob Lowry
    Great, NAPA sells the gl*** bowl filters and parts still....here is how a vette came with dual quads.
