Technical Dual Quad Hemi Linkage
Discussion in 'Traditional Hot Rods' started by gbgh, Jul 14, 2016.
  1. gbgh
    gbgh
    For reasons yet to be explained, I have installed a Weiand Dual Quad Intake in my 331 Hemi.powered 32 3 Window. I'm running Edelbrock carbs, (it was formerly running a Holley). It has an existing Lokar linkage, but I end up with very little firewall to carb clearance, which results in geometry problems. Can I run these carbs non progessive and linking to the front Carb?
    Or, better, if anyone has had a similar dilemma, any suggestions, especially with pictures, would be very welcomed
  2. AHotRod
    AHotRod
    I can tell you this, my Buick 401 Nailhead ran way better with a one-to-one linkage on the dual quads verses progressive.
  3. Atwater Mike
    Atwater Mike
    Edelbrock carbs, especially 600s: Straight linkage works great, as primaries are so small. Good throttle response, easy adjustment.
    I have a Weiand 2X4 intake on my 354 Chrysler Hemi, two Edelbrock 600s. Nice.
    Linking the rod to the front carb is O.K., advise you use 1/4" rod, spherical rod ends. Any slop in linkage (between both carbs) will kill any 'fine tuning' you have done.
    Final tuning should be done with a screw fixture that tenses linkage from the throttle pedal: just take up slack by increasing RPM to about 200 above idle; now set carbs the same at linkage with a uni-syn, so both air horns are vacuum checking the same.
    Release tension, adjust idles and air corrections. Final uni-syn check at idle.
    Good linkage is as important as tight bushings at throttle ****erflies!
    A final note: Install return spring in same plane linkage is pulling from.
    (Avoid applying spring tension that will result in having a 'sawing' effect on throttle bushings!)
  4. gbgh
    gbgh
    Excellent! Thanks
  5. gbgh
    gbgh
    Great Information!
    Many thanks
  6. gbgh
    gbgh
    Good Intel!
    Thanks
