Duece steering option
Discussion in 'The Hokey Ass Message Board' started by turdytoo, Oct 4, 2013.
  1. turdytoo
    turdytoo
    Curios if anyone has tried using a Corvair steering box with the modifications that seem to be fairly common when using F-1 boxes in '32 frames with driver side drag link. I have used the Corvair box to cross steer a '32 more than once and been very happy with its recirculating ball mechanism and I have used Gimmer boxes without being really pleased multiple times. With the aluminum box being easy to weld on and reversing being an option, I thought I would ask before attacking this as a project.
  2. A Boner
    A Boner
    Reverse a Vega box for drag link steering.
  3. HRP is gonna get you for your spelling of "duece"...:D
  4. turdytoo
    turdytoo
    Justly so.
  5. turdytoo
    turdytoo
    Vega is reversable?
  6. A Boner
    A Boner
    Yep....just have to cut down the BIG threaded nut, to make room to install a u-joint. Turn off the nut, and drill 2 holes in the end, so you can use a spanner wrench to turn, what was, the BIG nut.
  7. You know better "DEUCE",,:rolleyes: HRP
  8. dsiddons
    dsiddons
    from Indiana
    How about a 32' box? Or a F1 box?
  9. turdytoo
    turdytoo
    I will probably use an F-1, which I have. My roadster cross steers with a Corvair and I cross steer my 3W with a Vega. I'm building a flathead chassis and was looking for a better draglink style box that wasn't noticable.
  10. dsiddons
    dsiddons
    from Indiana
    I see. I had a 32' box in a 32' and it steered nice and tight. The f1 box works well and pretty sure the later 46-48? cross steer boxes work well and still traditional.
  11. turdytoo
    turdytoo
    Scratch this brain fart, Corvair box to short on the housing and sector shaft.
