Duel Function Gauge Manufacturer
Discussion in 'The Hokey Ass Message Board' started by Baron, Aug 12, 2010.
  1. Baron
    Baron
    I have a good friend who has been searching for the manufacturer of these smaller instruments for his Deuce pickup without success. They are dual instruments with two functions in each. Don't know if the Speedometer
    is by the same manufacturer. Hoping someone here will have the answer for him. Thanks !
  2. Busted Knuckles
    Busted Knuckles
    Look to be VDO look at European cars .
  3. I believe the small gauges are 40's Stewart Warner's, and very rare.
    HemiDeuce.
  4. propwash
    propwash
    from Las Vegas
    small aircraft use dual function gauges, but many of them don't mount the way hotrodders like.
    dj
  5. marks914
    marks914
    Alliance Vendor
    Ours go the other way, but maybe we could flip them around to point inward and add the cover like in the pic.
    Ours alr also 3-3/8, could probably mount them from the rear and make a smaller bezel.
    I believe those are AC gauges from an early GM
    Mark
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Smiths had a dual gauge, oil pressure and temp, if I recall. Found on Triumphs and stuff.
  7. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    That would be cool, Mark. Maybe give it a try?
  8. saveoursteel
    saveoursteel
    Stewart warner like it says on the speedo.
