Hot Rods Dumb A-s spindle question
Discussion in 'The Hokey Ass Message Board' started by PHIL COOPY, Sep 16, 2016.
  1. PHIL COOPY
    PHIL COOPY
    How come these spindles won't fit on this axle? The distance between the bosses is about 2 1/2 inches. There is no room left for the bearing. Backing plate holes are 3 1/16 and backing plate center is 3 5/8.
  2. Tim_with_a_T
    Tim_with_a_T
    I believe you have '35-'36 spindles on a '37-'41 axle. The kingpin and bearing is different on a '35-'36 axle. Not saying what you have for sure won't work together, because I don't know, but I'm pretty sure that's where the holdup is.
    gimpyshotrods and WiredSpider like this.
  3. you would be better off using `37-`41 round or `42-`48 square spindles and the appropriate kingpins
  4. PHIL COOPY
    PHIL COOPY
    Thanks..I knew the spindles I had looked strange to me...
    Phil
  5. PHIL COOPY
    PHIL COOPY
    Measured Kingpin centers...50 3/4... 46-48 car axle. Kingpin bosses on spindles are about 2 1/2 apart....35-36 spindles I guess. Paid $27 on ebay..no great loss. Shopping for nuther set.
    Phil
  6. alchemy
    alchemy
    The spindles up through '36 use a kingpin with the bearing above the spindle. You can still use those if you want with that axle. But getting some '37 or later spindles will simplify stuff a bunch regarding brakes and kingpins.
  7. No question is dumb A-s. We are all learning. Thanks for bringing it up; I'm a little bit smarter now.
    hidez57 likes this.
  8. PHIL COOPY
    PHIL COOPY
    I know...it just seems that way when you're asking a bunch of veteran rodders..
    Phil
  9. Here is a pic of a '34 axle with the top mounted thrust bearing.
