Technical Dumb Alternator Bracket Question
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Jul 9, 2020.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Without bone yards any more in Ca. to experiment and or look at things of old. Old, yes that's it. I can not remember if a bracket listed for headers will work on early Chevy exhaust manifolds. Will these two marry up to one another without having belt alignment issue? Thanks
  2. squirrel
    Just Gary likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ That's exactly why I'm asking. $$$$$
  4. squirrel
    I think the bracket you pictured, is designed just to what you want to do with it. If you have to move stuff around to make it work, that's easy, compared to spending vette part money. And repops usually cost a lot less than NOS
    Just Gary, scotty t and Johnny Gee like this.
  5. Mr48chev
    pitman and Johnny Gee like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That's how I see it as well. I'd also bore rear pivot hole bigger to put sleeve in that slide like OE's did it as well.
    squirrel likes this.
  7. stillrunners
    stillrunners
    from dallas
    Are you looking for the factory brackets for factory manifolds ? Or running headers and looking for that kind of bracket ? Factory brackets for factory manifolds shouldn't be hard to find.......
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    For manifolds. As for finding, that's not the problem. As I stated I'm not spending big many to be correct. I just need something that works with the least amount of money spent.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No kidding. I've skipped on them for a long time. Now that I need to go them again, well, you know why I/we can't go.
  10. Hnstray
    Hnstray
    from Quincy, IL
    In the span of time this thread took through post #10, a part like that could have been made in even a minimally equipped home shop.
    1” x 1/4” mild steel strap stock, a hacksaw, a drill, a vise , a hammer and a good file or bench grinder. A welder would be handy, but alternatively, the pieces could be bolted together.
    Ray
  11. TrailerTrashToo
    TrailerTrashToo
    Note that 1/4" strap is too thin - I bought one at a speed shop (30+ years ago) and it soon cracked from the engine vibration.
  12. 1971BB427
    1971BB427
    from Oregon
    That bracket pictured is only half of the set! There's a 2nd half that bolts to the front exhaust port on #1 cylinder and then that bracket bolts to it. The first half has slots in it to allow the piece shown to move forward or back to align the belt.
    Like these:
    You can use these on headers, or cast manifolds. But you'll need to use spacers under each bolt head to clear the manifold on cast iron manifolds. I just cut them from thick wall tubing.
  13. Budget36
    Budget36
    Do you have a welder and a drill press? My thinking is if you have to buy a part then modify it, just make your own.
    Boryca likes this.
  14. nochop
    nochop
    from norcal
    Smog pump bracket, if you can find one
  15. You're right, 1/4" is too thin also.
  16. 41rodderz
    41rodderz
    from Oregon
    That is probably the easiest bracket to make but I know a local parts place has them in chrome. I think they are Mr. Gasket brand . Like $16.00
  17. BLACKNRED
    BLACKNRED
    There's a boneyard in Tehachapi, Dennison Road
  18. squirrel
    Uh....look again at the first post in the thread. His manifold has this part built in. The bracket you showed is designed to work with headers, after you remove the manifold that he is installing
    1oldtimer, lothiandon1940 and Hnstray like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Problem is I'm laid off due to Covid. The vast majority of my personal tools are still there. All the big stuff that makes this super easy to make will cost $20 in fuel and 2 hrs of travel.
    It's the combination of both header bracket and alt bracket causing the flex. Not my issue here.
    TrailerTrashToo likes this.
  20. Gman0046
    Gman0046
    There are 9 pages of Chevy alternator brackets for auction or purchase on eBay right now.
    lothiandon1940 likes this.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Pay closer attention to some of those shipping cost's.
  22. olscrounger
    olscrounger
    Have used both types over the years--wife's 55 has had one with the header mount as well for 35 years-no issues-on the stock top long curved arm they used to break too at the adjustment slot-we always welded two together. I'll look in my junk-may have one.
    Johnny Gee and lothiandon1940 like this.
  23. lumpy 63
    lumpy 63
    Hey Johnny pm me your adress I'll send you one.
    Johnny Gee likes this.
  24. DDDenny
    Johnny
    I have a cast OEM alt mount, it's for 64-67 V8 ChevyII/Novas, I can send you one if the bolt spacing matches your needs. I'm on my way out the door but can measure it and post a photo this afternoon.
    By the way, I also have some misc. alternator adjuster arms, the curved ones, let me know your needs.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thanks for the offer. The one you speak of is the high mount one correct? If so it uses a different adjuster arm that mounts to both water pump and intake. On a personal level I'd like to stay as low as possible and keep the look as close to 1956 as I can.
  26. DDDenny
    Sent a PM Johnny.
  27. mitch 36
    mitch 36
    Honestly, the bracket/mount looks quiet like the alt mount on a 250 inline. This is just my memory speaking here!! I’ve got a spare if you need one. Then all you’d need was the other steel plate part, easy enuf to fab up I’m sure. PM me if it’ll work and you are in need , only cost ya shipping from Denver. Mitch
  28. 1971BB427
    1971BB427
    from Oregon
    I did see the manifold he has is the type with the built in alternator bracket. But the bracket he pictured is the type used with the header bracket I pictured. And I've used those for both headers and cast iron manifolds. As I mentioned, just need thin spacer bushings to use them on cast iron manifolds. It's easy to cut that factory casting off if the holes don't match up.
    I'd make a new bracket if I wanted to fit the existing manifold cast bracket, before I wasted time trying to modify something, and maybe end up with an ugly bracket. Unless it lined up perfectly with the pulley, and the manifold. Even if it lined up with the manifold, there's no guarantee it lines up the pulley. But with the two piece bracket you have adjustable to slide the alternator forward or back.
  29. squirrel
    I'd get a used, stock bracket that was removed from one of those manifolds, myself...
    Sporty45 likes this.
