Dumb FNG Question
Discussion in 'The Hokey Ass Message Board' started by Flathead Lobo, Mar 20, 2006.
  1. Flathead Lobo
    Flathead Lobo
    :confused: I am trying to put my flathead in the 48 tudoor, but I have a small ? problem. Somebody welded in motor mount perches that are about 4" above the original crossmember. I don't know if the original setup was like this? Does anyone have pic's of how the mount's are supposed to look? Thanks!! The motor is an 8BA out of a 51 F5.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They may have been using different water pumps than you are. There are a few variations.
  3. Flathead Lobo
    Flathead Lobo
    Do the mount's go down on the crossmember then? Thanks!
  4. Bruce Lancaster
    Bruce Lancaster
    Original mount location will be a donut shaped dimple on crossmember. If the extensions are indeed Merc '49-51, and that is what they sound like, the hole for the merc mount will be nearly but not quite in line with the Ford hole 4" down.
  5. Flathead Lobo
    Flathead Lobo
    Thanks! I cut off the extensions.,dropped the motor down, fits! Looks good.
