Dumb new garage find Question... How to remove a 65 Riviera shift knob?
Discussion in 'The Hokey Ass Message Board' started by Baumi, Jul 4, 2013.
  1. Baumi
    Baumi
    I got a new project, an almost finished 65 Riviera. The Pre owner started the resto in 88, drove her once to his own wedding in 89 and parked it ever since. He´s moving to florida and selling his stuff in Europe, so I ended up with a brandnew 65 Rivi.All that´s left to finish is the interior but the shift is challenging me, hahaha. I don´t want to break it, so can anyone of you guys give me the details on how to remove this little ****er?
    Thanks a million!
  2. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    If it does not unscrew off the top - Look for a small set screw in the side?
  3. theHIGHLANDER
    theHIGHLANDER
    I'm just gonna hate on ya for a while. Damn, that's a nice one.
  4. HOTRODPRIMER
    HOTRODPRIMER
    It probably has a set screw near in the chrome base of the knob or in the lower part of the knob. HRP
  5. Baumi
    Baumi
    Highlander, that's alright. I really deserve that, hahaha
    I looked for a set screw but couldn't find one... Maybe i should look closer...i dont think it is a screw on type knob, it won't turn in any direction...
  6. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    It unscrews! Might have to get a set of channel locks on there for grip, just be mindful of scratches and teeth marks!
  7. Baumi
    Baumi
    Ok, no set screw there.. I tried to unscrew it ( counterclockwise of course) I can turn like a half turn back and forth... May you have to pry the plastic insert out to ut I´m worried to break it....any more ideas?
  8. mashed
    mashed
    from 4077th
    Wrap an old leather belt around it and use channel locks.
    Twist on that mofo. Worse comes to worse I'm sure it's a catalog item.
  9. b-bob
    b-bob
    If you wreck it, then I would remove the handle from the column and place the knob in a vice and crush it. I have had to do that before. I think a lot of the knobs are a friction fit and a b8st8rd to get off. Good luck, try the belt thing, that may work....
  10. ronotron
    ronotron
    Ummm....pic shows a floor shift....
  11. theHIGHLANDER
    theHIGHLANDER
    If it's 2 piece, possibly the ***embly comes apart to reveal an inner c-clip. Later year GMs also had a clip under the knobs but the push ****on top came off 1st anyway.
  12. 56premiere
    56premiere
    I am thinking that you push the ****on down as you turn. But It has been a long time since I put carpet in one.. Good luck. Jack
  13. slacker1965
    slacker1965
    it just unscrews counterclockwise... if it hasn't been modified..
    you may have to soak it with some penetrating oil...
    the belt trick should work....
    the shifters/knobs aren't hard to come by here in the states
    nice car btw....
    the riv owners org is worth the money....(tell them I sent ya :)
  14. Baumi
    Baumi
    I got it off finally. It´s just screwed on, but mine had some loc***e on it which made it harder to break loose. Thanks for all your help! The leather trick plus a set of pliers were stronger than the loc***e:)
  15. theHIGHLANDER
    theHIGHLANDER
    Kool. Now I'm going back to hatin on ya just a wee bit more:cool:
  16. b-bob
    b-bob
    Oops! Must be my meds, yeah that's it.:eek:
