dumb shaved door question
Discussion in 'The Hokey Ass Message Board' started by hotrod54chevy, Jul 25, 2005.
  1. Drive the 4 hours to me and I'll do it for you. I'm in Windsor Ont, across bridge from Detroit Mi.
    Ryan, "The Goof"
  2. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I live in Cincinnati and you can use my oxy-acetylene setup if you drive down here and wanna do it in my garage. I'm kinda weird about using compressed gas tanks that have sat in the back of the truck for a couple hours, so I'm not gonna head up there. I'll warn you, though - I'm a BEGINNER welder and have spent more time reading about it/watching videos than actually welding. I'm working on changing those ratios, though...
  3. fatcaddi
    fatcaddi
    cool man .. let me know i contacted my buddy from school ,, he said he might be able to give ya a hand there in columbus so let me know whats up ,,, and redneck smooth id be careful if your a beginer with oxy welding,, sheet metal likes to fade away real quick like,,it takes some talent to weld sheet metal with oxy ive got some time with it and it still kicks my *** sometimes,, and hr54chevy, sorry if i seemed harsh earlyer i just hate having to do things twice,and just trying to look out for ya ive done some dumb things in the past that dont need to be mentioned, and also if you use a mig to shave em make sure you move any thing flamable and at the very least tape off the windows no one likes little metal balls stickin in your windows,, on the subject of frenching the taillights ya that might work a quater panel doesnt get the abuse that a door does (opening closeing,, drunk friends slamming them) so i hope everything works out for ya bro
  4. speedaddict
    speedaddict
    from Austin, Tx
    There you go creepy... lots of cool people offering to help you do it right. POWER OF THE HAMB
  5. This offer is open to all. I know there are a lot of members in the Detroit MI area. Come on over where your dollar goes further, I'll even show you around our stinky little city (we do have a Casino where your winnings are tax free).
    I also have a Bridgeport machine in my home shop to mill anything up you might need and am working on getting a lathe soon. Besides, Canadian beer is plenty good.
  6. Dat Dirty Rat
    Dat Dirty Rat
    WOW...I just read this....Your the man holmes!
    I'll help where i can as well..
    Not many people would do this...It shows what kind of guy you are Bob!
  7. 54BOMB
    54BOMB
    I think the hardest part of shaved door handles is remembering to get your keys out of the ignition in the garage or rolling a window down at the gas station , ha ha. Before you get them handles welded up install a emergency release of somesort.
  8. Sounds like you have it under control now, but I'm gonna go ahead and answer your question with regards to the JB Weld type thing. Yes...you can do it. YES...it WILL work. AntiChrysler had to do it on his car. He wanted his antenae shaved (I'm not gonna get into WHY it wasn't shaved prior to paint) The car was already painted black with blue pearl. This meant welding up the hole and grinding it smooth woulda wrecked a BIG area which woulda been hard/impossible to hide/fix. We filled the hole with a patch (washer) and 5 Minute Steel. Sanded, primed, sprayed the black. We layed out the flames he wanted added to the car and I made sure to carefully lay a lick of flames over the freshly shaved area. I saw the car after about 2 years of HEAVY drive time...no signs of cracking or anything. In a perfect world, you weld. In my world, you do what you can. :eek:
  9. theHIGHLANDER
    theHIGHLANDER
    Like barnett said, you can do whatever you need to. What your concern will be is the amount of epoxy used (thickness, sq inches). The expansion/contraction rate of the epoxy will differ from the steel. That's where your future problems with final fillers will come from. If you could mechanically attach your pieces with temporary screws then leading them in becomes an answer (also said above). The last but nasty way of doing it is with mapp gas and brazing rod. I think the heat required to get the br*** to "run" would warp the **** outta the doors tho.
    I also feel it'd be best to wait until a welding solution is found, but it's just the best way to skin your cat.
  10. hotrod54chevy
    hotrod54chevy
    from Ohio
    wow,this was an old post,i'm surpised how many people read it! thanks for the help,but i should be getting a welder and grinder for christmas so i shouldnt have to worry about this too much
    creepy
