Technical Dumb
Discussion in 'The Hokey Ass Message Board' started by TINGLER, Jul 14, 2006.
  1. TINGLER
    TINGLER
  2. jusjunk
    jusjunk
    from Michigan
    Put the center section back in and slide the axles in. They should go in a lot easier than they came out. you will have to guide em in the side gears in the center then push em in the rest of the way .
    Dave
  3. Thirdyfivepickup
    Thirdyfivepickup
    Would just tap them back in using a block of wood on the flat face of the axle pad. Thats they way I did it on my 9" I assume the 8" would be the same?
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    yep. just line up the splines and bonk away. it makes it alot easier if you line the blots on the flange up first,though. and don't forget the small amount of pookie around where it all comes together.
    small,small amount.
  5. Also, it's kind of obvious, but make sure to clean the outer bearing races & the inside of the ends of the axle tube where the bearings seat, and clean the retaining flanges a little. I've seen people just go to put it all back with it all cruddy and get a little chunk in behind there, then the bearing won't seat all the way. It's cocks the bearing a little then it'll usually develope a bearing roar. Piece o' cake. :)
  6. i'd replace the seal inside the axle tube too.....CR part# 13700
    how are the axle bearings?
  7. SinisterCustom
    SinisterCustom
    WTF! You shouldn't have to beat axles back in.
    If everything is clean they will slide in.
  8. thunderbirdesq
    thunderbirdesq
    Yeah, in my experience, they should just drop in with maybe a slight bit of resistance from the bearing seating. But nothing more...
