History Dumbass numbers question
Discussion in 'Traditional Hot Rods' started by jim1932, Oct 31, 2013.
  1. jim1932
    jim1932
    OK… been wondering on this for a while… how do you decipher the numbers on the side of a hot rod? I am thinking the number Id's the car and the letters are the cl***?
  2. chromeazone
    chromeazone
    I would say yes, but too many tracks, strips and hot rod organizations to have commonality for determining anything!! They could mean anything from birthdays to girl friend's bust size!
  3. jim1932
    jim1932
    I guess the question goes to the guys with numbers on the car. Are they historical? or likE "32 B" for a deuce
  4. squirrel
    depends on the car....and what type of racing it did, or is trying to look like it did.
    You can look up the cl***es for current land speed racing cars here
  5. metal man
    metal man
    This is NHRA from 1959
    Maybe someone else can make the image larger. I don't know how, but if you click on it a couple of times you can read it.
  6. Steve!
    Steve!
    from at the gym
    are these the dumb*** numbers you speak of
  7. saltflats
    saltflats
    from Missouri
    Not sure about the XF but the GR would be for gas roadster.
  8. jim1932
    jim1932
    PLEASE!!!! I did NOT say dumb*** numbers….I twas a dumb*** QUESTIOn for me not knowing what they meant. I am not criticizing anyone for putting them on, wanting to understand them in case I wanted to put them on.
  9. metal man
    metal man
    HaHa, I would have never even thought of it that way. I think you were very clear about it, and Steve was joking.
  10. jim1932
    jim1932
    OK so put up…. what does the C/G 777 mean? :D
  11. metal man
    metal man
    C/G = C gas . Which was 11 to 12.99 pounds per cubic inch.
  12. jim1932
    jim1932
    So did they weigh the car? how did they know the LB's pr inch?
  13. metal man
    metal man
    They weighed the car, and measured the bore and stroke.
  14. Larsdk
    Larsdk
    XF is flathead Ford in SCTA. So the roadster in your picture is in the flathead powered gas roadster cl***.
    I think the "B" is from the old days when the size of the engines was from A to D, with D being the biggest.
    I hope this helps you.:)
    Lars
  15. jim1932
    jim1932
    So where does the number come in? Were you ***igned a number that was the same at every event? I know when I raced in the 70's they used shoe polish to put the number and cl*** on the window but you got a new number every week,
  16. squirrel
    depends on where you're racing. Land speed racing numbers usually stay with the car. Drag racing numbers used to change every weekend. Now they stay the same in some places, but change at others.
  17. Speed Gems
    Speed Gems
    At Bonneville the letters refer to engine displacement.
    AA 501+ ci
    A 500-440
    B 439-373
    C 372-306
    D 305-261
    E 260-184
    F 183-123
    G 122-93
    H 92-62
    I 61-46
    J 45-31
    K 30.5-under
  18. Mr48chev
    Ah come on now, it' pretty lame to shoe polish numbers on your car when you go to Bonneville in a car that is obviously not a race car so people will take photos of it.
    Speed Gems pretty well nailed it on the cl*** thing.
    These days though it seems the "thing to do", for the poser crowd is to paint numbers on your rod when you go to Bonneville so people might think you have a "real" race car.
  19. Bruce Lancaster
    Bruce Lancaster
    For any modern number, like a current Bonneville car, you need the appropriate rulebook.
    For a number based on nostalgia, you need to decide on a year and find either the rulebook or reasonably similar cars in ancient magazines.
    Cl*** breaks changed frequently (remember, through the '50's and '60's bigger and bigger displacements were becoming available), obsolete engines got separate designations, and less frequently equipment rules changed. Don't just copy anything current you see...there are many highly incorrect cars cl***ed as g***ers, etc.
  20. Larsdk
    Larsdk
    That is right, but they used to be:
    A Cl***....0-150 Cui
    B Cl***....150-250 Cui
    C Cl***....250-350 Cui
    D Cl***....350 Cui & over
    Lars
  21. larry woods
    larry woods
    from venice fl
    For the particular car you have pictured those are the numbers and cl*** when it was run at Bonneville. Car was driven from upstate NY then transformed to meet safety requirements (roll bar cage installed), run on the flats, transformed back and driven home! Yes it is a "Bones' car", flathead power! I have had the privilege to ride in it and drive it on the way to Bville '12. The rest of above info should answer general questions.
  22. Larsdk
    Larsdk
    But the "B" must refer to the old engine cl*** system. I doubt that it has a flathead with 439-373 cui. Thats a pretty big flathead.
    Lars
  23. jim1932
    jim1932
    It is always a learning experience. I was ***uming drag race numbers, most responses are speed run numbers.
