Technical Dump find
Discussion in 'The Hokey Ass Message Board' started by Jack, Jul 13, 2014.
  1. Jack
    Jack
    from Austin Tx
    Found this at the dump today. Any ideas what this is off of?
  2. Rusty Junk Ranch
    Rusty Junk Ranch
    Late 40s, early 50s Pontiac is my guess!
  3. Can't read the size, if 16" then it is prewar (42 or 41), if 15" it is '46 and later, Pontiac wheel...
  4. Just curious how you guys can id as Pontiac. Is it the triple pinstripes? I mean I would have guessed early fifties Chevy p/u. but what do I know?:confused: Cool find anyhow, whatever it is.
  5. 1934coupe
    1934coupe
    Check the BC first it looks like but its hard to tell a 4-3/4"BC and the hubcap tabs seem like early Chevy late 40 early 50s, A 5" BC would indicate Buick, Pont, Olds. Buick had a hole for a pin to align the wheel up to the bolt hole and they used bolts, it doesn't look like Olds. If it's 4-1/2" it may be 49 Plymouth-ish.
    Pat
  6. 3wLarry
    3wLarry
    from Owasso, Ok
    enlarged the pic, and the tire is a 6.00x16 Firestone
    kidcampbell71 likes this.
  7. Lotus Europa. :D HRP
    lothiandon1940 likes this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    The three hub cap clips suggest GM and I agree it's likely a late '30s/early '40s Pontiac, maybe Olds. Without a locating pin hole eliminates Buick and most Mopars. Nice condition and a trim ring too......cool find!
  9. squirrel
    what, you didn't work at a junkyard when you were a kid?
  10. X2!:rolleyes:
  11. 51 Super
    51 Super
    from Iowa
  12. 51 Super
    51 Super
    from Iowa
    Hard to tell in my pic, but is has the pinstripes & clips for the center cap.
  13. squirrel
    take the cap off the buick wheel, you'll see how different it is
