duntov solid cam???
Discussion in 'The Hokey Ass Message Board' started by slamchop, Jun 3, 2004.
  1. slamchop
    slamchop
    from San Diego
    Got a solid cam in my 283 and tryin to find the valve lash???Thought it was .010 but not sure. [​IMG]
  2. k9racer
    k9racer
    If you have the old 097 or 098 also packaged as Mellings C8P try 12 and 18 for the street. Some ran 8 on the intake for higher revs. I hope this helps..
  3. IBUILDM
    IBUILDM
    If it is a Duntov 20-20 it means the valve lash should be .020 on intake and exhaust.
  4. slamchop
    slamchop
    from San Diego
    Ahh.....so if its a 30-30 it should be .030?
  5. k9racer
    k9racer
    the 30/30 cam is 3849346 or mellings c10p it sets on 30 intake and exhalst.
  6. slamchop
    slamchop
    from San Diego
  7. metalshapes
    metalshapes
    [ QUOTE ]
    [/ QUOTE ]
    An old Hot Rodder ( he played with this stuff when it was new ) told me they run better with a tighter clearance.
    Is that true?
    I can see how that would give more overlap, but would that make you burn the valves or something like that?
  8. BELLM
    BELLM
    The Duntov 097 was early Corvette cam, , , I-12 & E-18 is right for '58 thru '61, '62-'63 340 & 360 hp were 18 & 18. The 30/30 was '63 up to mid 60s Corvette 375 hp FI cam, 30 & 30 ran good for me. Around '66 the 350 hp 327 had a good hydraulic cam, much more streetable than the FI cam, esp with an automatic. Ah, memories, hearing a C series AFB wail at about 6500 [​IMG], drilling & pinning rocker studs because they kept pulling [​IMG].
