duplicolor engine enamel
Discussion in 'The Hokey Ass Message Board' started by demmals7ytriht, Apr 21, 2011.
  1. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Has anyone used dupicolor engine enamel? Thats what Im using to paint the engine Im working on. After priming the block I read the small print and it says it has a 7 day cure time, the color Im using says the same. WTF 2 weeks to paint a motor, did I read this wrong or could this be right.
    The next question, is this a good product or am I wasting a couple of weeks?
    Thanks,
    Billy
  2. EnglishBob
    EnglishBob
    Cure time and recoat time are different.
  3. I painted mine with Duplicolor and it's holding up great. I cleaned the engine very well first with wax and grease remover etc. I never used the primer though but 4 years later the shine is still there and it has not peeled. I put on 2-3 thin coats.
    It has held up very well.
  4. NM Sandrail
    NM Sandrail
    Hi...
    I used Duplicolor Ford Blue #DE1601 ceramic engine paint on my '85 Nissan engine block, back in 2004. It has held up just fine...no primer used.. I didn't wish to use the Nissan colors.. Says on the can 5 days to cure, but dry to touch in 1 hour and can be handled in 3 hours. I waited more than the 5 days, before the engine was finally ***embled and started. Was painted inside on a Missouri winter.. Super paint for me..:). Good Luck with yours...duane (NM Sandrail)
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thats 7 days to recoat. If you find that it needs recoating the next day forget it. It lifts, I know. Good **** other than that. Also I've dropped and fired engine less than 24 hrs after painting and no problem.
  6. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Thanks guys, this is a recently rebuilt used engine, not greasy at all but paint had some flaking around the top of exhaust ports on heads, and around the timing cover, it's a 283. I used GUNK gel engine cleaner, and a pressure washer just to see if it would break loose any more of the chipping paint, then washed it with dish soap and water thats why I used the primer. Im glad to hear positive feedback.... but Im still not sure when I can put the color on.........
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just after you have done the last washing with dish soap. Helpful hint, I use Scotchbrite while doing final wash. Helps dull old paint if any behind and helps remove flaking as well. Good luck
  8. tig master
    tig master
    from up north
    I have used lots holds up well.
    Tig
