Technical Duplicolor Rust Barrier spray paint
Discussion in 'The Hokey Ass Message Board' started by 27Tudor, Apr 11, 2018.
  1. 27Tudor
    27Tudor
    I was looking for POR15 and this was on the shelf next to it and looks similar for less money. I may take it back and get the real deal POR15 but thought I would check with the experts first. I plan on using it for painting the inside surface of the side cover on my model t banger. Will it last when subjected to oil, ***uming I follow proper preparation instructions?[​IMG]
    Sent from my SM-N910V using The H.A.M.B. mobile app
    Elcohaulic and chryslerfan55 like this.
  2. hotrodA
    hotrodA
    I wouldn't use that. If the inside of your cover is rusty, I would suggest blasting or wire brushing the rust off to clean metal and leave it bare.
  3. Bandit Billy
    Bandit Billy
    Doesn't look like you have anything to do after 4:00 so spray it and report back.
  4. I haven't tried that product yet
    we do experiment with different products at school
    during our bus build, we used rustolium rusty metal primer on our core support and inner fenders
    removed all the loose rust and sprayed, a year later and thousands of miles it still looks great
    but for the inside of an engine I think I would soak it in rust remover and leave it bare
  5. 27Tudor
    27Tudor
    Nobody likes a smart ***!
  6. indyjps
    indyjps
    Ah, that was funny.
    Ive tried a lot of spray and brush on rust converters and been disappointed every time (1-2 years later) POR 15 is the only thing thats worked for me over rust. Im still not sold on it because it has peeled on me on non rusted areas.
    Getting the rust killed is key, just wire wheeling it, the rust is still kicking. Mol***es, acid, evaporust etc. Anything to get the rust process neutralized, tyen remove the chemical. This allows paint of your choice to go directly on steel.
  7. Bandit Billy
    Bandit Billy
    These guys did:cool:
  8. 27Tudor
    27Tudor
    Bandit Billy likes this.
  9. badvolvo
    badvolvo
    Trust in evaporust! stuff is pretty amazing.
  10. BJR
    BJR
    Wrong.... Some of us do.
  11. FrankenRodz
    FrankenRodz
  12. Petejoe
    Petejoe
    from Zoar, Ohio
    Engine heat and contaminants
    I’ve always had good luck with this.
    Elcohaulic likes this.
