Hot Rods DuVall Windshield Frames
Discussion in 'The Hokey Ass Message Board' started by GR5, Feb 12, 2019.
  1. GR5
    GR5
    Hey Guys,
    Hopefully this hasn't been discussed, at least not recently.
    I really dig the look of the Duvall windshield frame on roadsters. I know Speedway sells one for the '30-'31 A and also the '32, but not the '28-'29. I also saw that O'Brien makes the Hallock frame for the '28-'29.
    I've seen pictures of guys with Duvall frames on their '28-'29 roadsters and RPUs, but I can't seem to find someone who repops them. Anyone know?
    Thanks for looking,
    Mike
  2. jimmy six
    jimmy six
    Duvall's were only for 32's as I remember. RIP Julian Doty, SCTA Sidewinder, knew all about them
    kidcampbell71 likes this.
  3. Dirty Dug
    Dirty Dug
    A friend of mine makes the Duvall frames that Speedway sells. He's making them now for '28-'29 roadsters as well.
  4. GR5
    GR5
    That’s great news. Will they be available through Speedway or direct from him?
    Thanks,
    Mike
  5. Dirty Dug
    Dirty Dug
    I don't think Speedway has them listed. He just recently had the patterns made. Direct from him would be cheaper.
  6. 08racer
    08racer
    from Gilbert AZ
    Do you have any info on these?
    lothiandon1940 likes this.
  7. john walker
    john walker
    Always wanted to make one for a larger car, like the early coach builders did. I ***ume the forms were made of wood andthen cast in br***/bronze, right? Cast whole, then cut later for gl*** insertion? What about the gl*** groove, how was that done. We should have a how to discussion on making these.
  8. jimmy six
    jimmy six
    28-29's were Duke Hallock's...a lot better that a Duvall style.
    fourspd2quad likes this.
  9. Dirty Dug
    Dirty Dug
    I think they're cast in four or five pieces. The gl*** channels are cast into the frame pieces
  10. john walker
    john walker
    The one I got from your buddy is two pieces. The top comes off for the gl***. Are the two sections welded together in the middle?
  11. Dirty Dug
    Dirty Dug
    Yes, I've only seen one set as cast and they look real rough. He has to do a lot of work on them when he gets them back from the foundry.
  12. A Boner
    A Boner
    The biggest problem is the pattern has to be made larger so when the cast metal cools, it will end up the correct size to fit the car it is designed for.....Shrinkage!
    lothiandon1940 and fourspd2quad like this.
  13. COCONUTS
    COCONUTS
    Some guy in El Paso, TX was getting them poured in Mexico and selling them through E-Bay. Real rough but with alum. not that hard to work with. Almost like you were doing the final shaping and finishing. I think that because he screw over to many people he is now out of business or else hiding out in Mexico.
  14. hfh
    hfh
    from Western MA
    IMG_1072.JPG The shrinkage problem is not difficult to solve. About 20 years ago I made a pattern for my windshield using pine. My patternmaker friend then added to the pattern for the shrinkage. I think the shrinkage is about 3/16" per foot for aluminum and bronze. He added a piece about 3/8" wide along each piece in the center of the windshield so that it would fit my cowl. We didn't care if the windshield got shorter in the casting. We cast it in bronze at a local foundry. The grooves for the gl*** were machined after the castings were made.
    I love the look of the Hallock windshields but living in New England I knew that I would need enough headroom to have a top. So my windshield is a bit taller and I have about 1/2" of headroom inside under the top. Since then I have cast two more windshields in aluminum using my pattern. IMG_1072.JPG
    kidcampbell71 and jimgoetz like this.
  15. jimgoetz
    jimgoetz
    Killer !
  16. Phil Carracho
    Phil Carracho
    from Atlanta GA
    Is your friend still making the windshields? Speedway is no longer offering them. They canceled my order month ago.
  17. Xman
    Xman
    I talked with Paul Wescott today and he is considering having Duval windshields either cast in bronze or investment cast in stainless steel. needs to see if there is enough interest.
  18. DDDenny
    Where is he located?
  19. Xman
    Xman
    Sorry, Wescotts Auto Restyling I'm sure you know them
  20. Rick Coast
    Rick Coast
    I installed one on a 32 gl*** roadster and he rolled the car over . he said being so strong cast it acted like a rool bar. thank god they came out with minor injuries.
  21. Hitchhiker
    Hitchhiker
    I have a br*** one for a T. Not sure that helps...
  22. Peter Nowak
    Peter Nowak
