Dz 302
Discussion in 'The Hokey Ass Message Board' started by Mitchell de Moor, Mar 21, 2010.
  1. Elkhartthunder
    Elkhartthunder
    I have a set of heads, from what I was told they are 302 heads and my research tells me the are, but how can I tell if they are DZ or not? Also, wondering what they are worth..
  2. Deuces
    Deuces
    For starters, do the last 3 digits of the casting number end with 186?? Also check the intake valve diameter with a pair of calipers... They should check at 2.020 inches... The exhaust valves at 1.600 inches.... You could also check the combuston chamber volume which should be around 65 cc's..
  3. Deuces
    Deuces
  4. nocoastsaint
    nocoastsaint
    I have one of the four barrel manifolds. Someone 'Knife edged' the divider though. Need to do something with it. The only use I've gotten out of it so far was the subject of an oil painting. That and it's fun telling people what it is.
  5. nocoastsaint
    nocoastsaint
    I don't know that I'd give up a nut for it. But I wouldn't hesitate to beat a ****** with a kitten for one.
  6. rosco gordy
    rosco gordy
    Those dz,s were bad mofo, s scared the piss out of me in 69...........and the 1st vid the red head with the black shirt .........cool what a drag strip I,m envious
  7. Deuces
    Deuces
    They weren't that bad.... I used to power shift mine at around 7200-7500 all the time... WOOHOO! :D
  8. Deuces
    Deuces
    I re-read this article again and I couldn't believe that the stock factory chevy stamped steel rocker arms ratios varied that much from 1.37 to 1.50. WoW!
  9. Bob W
    Bob W
    from Here
    Those stock rockers were all over the map. I had to go through 64 of them to get 16 that were the same for a 283/220 engine is NHRA Stock.
  10. Deuces
    Deuces
    Is there a way to check the rocker ratio of a stamped steel rocker arm??? If so, please explain! Thanks!
  11. Wildman1
    Wildman1
    I've got a box out in the barn with 7 Jahns 301 pistons & rods - guess where the 8th went, and why it went ......
    Oh well, in '68 good 283s were VERY abundant! :rolleyes:
  12. Deuces
    Deuces
    Is this a guessing game?? :)
  13. Kazoom
    Kazoom
    Hi Weasel, if you out there... would you (or anyone here) by chance know or ever heard of any of these 32V Weslake heads that were made for the SBF engines???, I heard from a guy here there were, but I have not been able to find any info on it yet.
  14. Your picture shows that Camaro with power brakes? I was always under the ***umption no power brakes on Z/28s 67-69?
  15. Larry T
    Larry T
    The date code will get you pretty close (DZ is 1969 only). But I don't think the heads were 302 exclusive either.
    Also, I've seen lots of heads that have been modified for 2.02/1.60 valves and guide plates. The factory 2.02 chambers are machined around the intake valve to unshroud them. No machining, not factory 2.02s.
    Larry T
  16. LabRat
    LabRat
    Thanks Mitchell , I learn't something new from this thread .
    fifTysix , 333Halfevil , Back in your box ...
    While Mitchell may be a dreamer , just like the rest of us !
    I have never witnessed him needing to speak **** ....
  17. The ole boy who built my D/G Stude back in the 60s bought a 1967 MO 302 from the Chevy dealer and had it balanced and blueprinted from the crate. He said it was a good thing he did as a couple rod bearing clearances were to tight! I bought the motor from him( with factory reciepts and shop tickets showing all work) and put it back in the Stude and ran it on the street and raced it at Cordova Drags and Byron Dragway back in the eighties.It ran 12.5 smokin the tires in all gears! I shifted that 302 at 8000! If I shifted at 7900 or 8100 it slowed down! Man was that thing fun on the street with 5:38s and a 4-speed! I usually ran a 3:08 open rear gear on the street and never did have it flat out! I know 66mph was 2600 rpm ( courtesy state police) and I had it wound up to 6600 when racing a Trans Am one day...I'm sayin around 150 + mph...That old Stude was rockin and rollin!!!!!NO B.S.!!!
  18. 68Camaro427
    68Camaro427
    I used to make my living as a heavy line tech for Chevrolet. I saw a couple of DZs during my stint. It's been said before - get some gears and hold on! They do like to rev!! :)
  19. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Wasnt a DZ motor but i built a 302 and put it in my midengine corvair a while back. It was bad ***. Only problem I had was I couldnt afford to buy gas for it. With 12 to 1 octane booster wouldnt cut it. Had to buy racing fuel at $10 a gal. Since I wont have a car I cant drive it went on CL and ended up in Baltimore and the new owner is real happy with it.
  20. F-6Garagerat
    F-6Garagerat
    sell it and finance a nice engine build
  21. rustednutz
    rustednutz
    from tulsa, ok
    In '73 my wife and I bought an all original (which at the time wasn't all that rare) '69 RS/Z28 for $1300.00. The highest gear ratio you get get with the 302 was 3.73. That really wasn't low enough as they had absolutely no torque at all. I ended up putting 4.56 gears, headers, Lakewood ******* bars and seven inch wide M/T cheater slicks and run 12.20's shifting at 7500 and going through the lights around 7200. This was my everyday driver until late 1975 when I decided to "knock it in the head" and make a drag only car out of it with a big block, ladder bars, fibergl*** frontend, etc. Pretty smart fella, huh? It would have been worth $60,000 to $75,000 today with the RS option.
  22. Deuces
    Deuces
    The 3.73 gears were standard for the Z/28...
    If the original owner wanted to, he could have checked off on the option list for a lower or higher gear ratio.. 3.55's, 4.10's, 4.56's... etc..
  23. X77D80
    X77D80
    from New Mexico
    Power disc brakes were mandatory on a 67-69 Z/28.
  24. Deuces
    Deuces
    Yep! Mine had it...
  25. falcongeorge
    falcongeorge
    from BC
    hell, I'd beat a ****** with a kitten for 3 milk duds and a half eaten big mac.
  26. Deuces
    Deuces
    The 302's also had a bigger diameter alt. pulley to slow the revs down... ;)
  27. Deuces
    Deuces
    I need to hit the Lotto!!!....
  28. ct1932ford
    ct1932ford
    I would love to own one. Next would be a 327/365 I would build a car around it.
  29. Shaggy
    Shaggy
    from Sultan, WA
    Then clone one, almost all the '67 DZ was off the shelf GM stuff
  30. X77D80
    X77D80
    from New Mexico
    Dang near these days... I've owned 4 real 69 Z's over the years, still have the Daytona Yellow car that the engine pic is from. It mostly just sits collecting dust in the back of the garage. I hang onto it since I know if I ever do let it go, I'll never be able to afford to replace it.
