Technical Dzus fasteners 32 hood sides
Discussion in 'Traditional Hot Rods' started by deucepickup32, Jan 4, 2026.
  1. Researching the installation of Dzus or 1/4 turn fasteners to replace the stock hold downs on my 32 Vicky. Anyone have some details with pics, measurements and what they used ? Picture of a Rolling Bones car for example.
  2. DDDenny
    These are from Full Bore Race Products but they are no longer in business.
    They use a hex wrench instead a slot screwdriver.
    Speedway has some that are about the same.
  3. Happydaze
    Happydaze
    Socal sell a neat kit. The fasteners have the aforementioned hex head and come chromed. Decide on the desired location, drill, dimple ( easy to make tool if you have a lathe), bend mounting tabs as necessary to mount to firewall and grille shell, mount tabs ( I used bolts and nuts). In my case I had the mounting tabs chromed. All looks neat and works great.
    Chris
    Lil 32 likes this.
  4. bowie
    bowie
    My ‘32 has used this style of Dzus fasteners since at least the mid ‘60’s to hold its aluminum hood top on. Over the decades, I have come across three different head variations to replace lost ones. The original one says Dzus on it. IMG_3939.jpeg IMG_3940.jpeg IMG_3941.jpeg IMG_3942.jpeg IMG_3943.jpeg IMG_3944.jpeg IMG_3945.jpeg IMG_3946.jpeg IMG_3947.jpeg IMG_2295.jpeg IMG_2294.jpeg IMG_2022.jpeg IMG_0352.jpeg
    Outback, warbird1 and deucepickup32 like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Speedway motors has a lot of different types of dutz fasteners. HRP
    CLICK HERE
    deucepickup32 likes this.
  6. pirate
    pirate
    from Alabama
    Aircraft Spruce is a general aviation supplier. If you go to thier website and do a search for “Dzus” https://www.aircraftspruce.com/search/search.php?s='dzus' it will show numerous styles and if you click on the style you like it will give dimensions. They are very good people to deal with. They are also a great source for rivets, latches, etc. used on aircraft but also great for hot rods.
  7. Thanks and I have been looking on their website as well. I spent 37 years as an aircraft mechanic and had access to them but that was before I needed them
    Outback likes this.
  8. Thanks to all who replied. I will probably use the slotted head variety as the hex look to modern.
    This will be a spring project as I am still working on the tank relocate.
    loudbang, Lil 32 and HemiDeuce like this.
  9. Thanks HRP
  10. A few years ago I had to replenish my supply. I used AA-MFG.com. They had better prices that the others I had used. There are many suppliers out there, though. These are flush mount that I use a simple tool to dimple the panel for. If you do some research you will see there are different lengths of ****ons and springs. Depending on what gauge of sheet metal you are using, you may need long or short. DSC03750.JPG DSC03754.JPG
  11. jaracer
    jaracer
    The correct tool for a Dzus fastener is not a screw driver. Although, you could modify one to work well. The tool needs a rounded end to properly engage the fasteneer.
    Also, the fasteners do tend to chip the paint around the opening. However, we had the hood on and off the car a lot to do engine maintenance and inspect things after races. dzus.jpg All the panels on my race cars were held on with Dzus fasteners.
    Outback and lurker mick like this.
  12. DDDenny
  13. patterg2003
    patterg2003
    Check out Skybolt fasteners. They are adjustable for various thicknesses and work most excellent. The airplanes at our flying club are equipped with the Dzus. The club Supercub had them and they are always a fight on that airplane. We built a 4 seater Bearhawk and used the Skybolts becouse they had more flexibility for material thickness. They work so much nicer with less fussing to lock and unlock. They can look as traditional as Dzus if you want. We set one up with all the thicknesses to learn where to set them then they all were set up the same then installed. Once they were set they worked flawlessly with no further adjustments. PS. Aircraft Spruce now carry some of the Skybolts. You can refer to the Skybolt site for the fine details.
  14. Turned many of those in 37 years. Thanks for the input
    Outback, patterg2003 and pprather like this.
  15. warbird1
    warbird1
    Snoopy Tool...
    bowie likes this.
  16. 31 Coupe
    31 Coupe
    I've always sourced mine from Good Vibrations Motorsports in LA.
    DZUS ****ons.
    gimpyshotrods and deucepickup32 like this.
  17. pirate
    pirate
    from Alabama
    Probably not all that traditional looking but I used these in a couple applications. Convenient, no tool required and saves on scratched paint from opening tool slips.
    Country Joe likes this.
  18. 31Apickup
    31Apickup
    I have those mocked up on my hood, no tools required haven’t decided if I’ll use them once painted.
    Outback likes this.
  19. DDDenny
    I used some of the "mickey mouse ear" style Dzus ****ons when they first came out, they tend to break off after a while.
  20. Outback
    Outback
    from NE Vic, Oz
    I'm glad somebody mentioned the special tool, they do work better in the screw slots.
  21. Groovy
    Groovy
    My solution... IMG_6217.JPG IMG_6348.JPG IMG_6349.JPG IMG_6181.JPG IMG_6183.JPG IMG_6272.JPG IMG_6293.JPG IMG_6593.JPG IMG_7794.JPG
    Just Gary, hotcoupe and deucepickup32 like this.
  22. youngrodder1929
    youngrodder1929
    .450 large diameter the small ones the spring isnt as robust so they don't hold as well. Mopac had a good selection of that stuff
    Davis
  23. Thanks Davis
  24. 19Eddy30
    19Eddy30
    from VA
    Aviation .. many shapes and styles.
    Best to use Slotted or winged .
    The Spring "S" set up & Depth is critical
    To far away hard to Lock & will snap off
    the wing style ,,, & if to loose will unlock .. there a tool to adjust the Depth
    Raise or lower the "S" spring .
    Can be made easily.
    The Hex or Torque heads to me Not good , I see many modern outside of notch and wing @ track There's been times when emergency happens and nobody has the tool to unlatch ..
    There are push ****on style.
    Nice, Not cheap for Good Quality made one's though
  25. woodiewagon46
    woodiewagon46
    from New York
    When I was in the navy I was stationed on an air base and we all carried what is pictured in post 11 in a holder on our belt. I don't know if there is an official name for it but we called them "Dzus Keys".
    Just Gary likes this.
  26. Groovy
    Groovy
    I used the steel 7/16" dia with a .400 reach. Ordered them from Jeg's...
  27. Thanks
  28. BJR
    BJR
    I'm sorry but this looks just WRONG.
    Fogger, mitch 36, loudbang and 2 others like this.
  29. oj
    oj
    One thing to consider before commiting to the slotted dzus is that it is very common for the screwdriver, dzus tool or a 'Snoopy' to slip off the ****on and rip across your paint, especially if there is a little misalignment from the ****on to the spring receiver - very common that. The advantage is thar an allen dzus you can use the allen wrench to aim it into a slight misfit without hazarding your paint job.
    Happydaze likes this.
